1987 350 to 150 swap
Hello im new to the site ( nice site by the way ) and i have a 1987 350 supercab dually RWD slite perfomance 7.5 (460), carb, auto, with pos and gear rear end . my question is can i swap the motor / trans and rear end in to a same year or matching year f150. i do believe the motor and trans can swap but the rear end is the question - daully back to single . Or well i be able to do a rear end gut swap . Please if anyone knows if this is ok pls inform . Love the power and traction just hate the body sometimes
You will need to swap your F350 coil into the F150 to take the 460 weight
You will need the 460 engine perches which are rivited to the frame
The dually axle will be a problem though. There is no way to convert it to SRW. The DRW axles are 6" wider than SRW axles so your tires will stick out 3" further than they are supposed to
YeOldeFord
07-19-2016 01:59 PM
D. McNelly
13
12-01-2003 10:25 AM
acerockola77
11-24-2003 09:24 AM
