Look at your electric bill and find out what a kilowatt costs. It's probably in the $0.10-$0.20 range. The block heater uses a kilowatt. Multiply that rate by how many hours and you'll have the actual cost.
If you are worried about actual cost, buy a $10 timer that can handle 20-30amps (3 prong plug) at a local hardware store. Have it turn on an hour or two before you would usually be starting the Ex to go to work. That way you only use what you need, when you need it.
You could REALLY get trick and get one of those Newmar (Havis-Shields) quick-ejects and mount it either under the front bumper or under the rear under the tail lights (if you back into your driveway). It ejects the power cord when it detects motor start.
One of those would be very nice, aside from the price. But how would you mount that so it isn't ugly and is still accessible without standing on your head?
I back into my driveway, so my idea was to mount it behind the rear tire (facing down) or just to the left/right of the trailer hitch (facing back). You'd have to fabricate something (maybe out of aluminum plate) unless you wanted to cut through the body like FD/PD units have, but it could be done fairly easy.
I don't have the block heater myself - I'd use it to put power to my aux power items (light chargers, laptop/iPad power, inverter, etc.)
i leave my plug in during the winter months .. with how cold it is and the use of electric heaters in this house . i dont really notice a deference .. unplug drive around come home plug in
Marinco plug for the block heater, with a waterproof battery tender wired to the back of the plug = warm happy engine and fully charged batteries! Genius!
How about a couple small battery warmers too? Need to be careful what you hook up though, I think the diesel block heater pulls 1100 watts. Add another 120w(total) for two batteries and you need a good extension cord to handle that power. Not to mention a pretty empty circuit.
They guys up North where it really gets cold do all sorts of crazy stuff like oil pan heaters and tranny pan heaters. Or they just never turn their trucks off...
I use a 1 amp charger, sitting next to the passenger battery, the cord may loose voltage, but wont got warm because of the temps outside. At .10 kwh 12 hrs would cost about $1.50, I use a cycle timer on for 10 seconds off for 10 seconds.
It takes a few hours to heat the coolant/oil up, but i think im saving $$$ by cycling. I believe when coolant/oil temp are 30-50 degrees about the outside temp, less engine wear during starting up. Plus the inside warm's up faster.
