possible IDM failure???
Old Dec 10, 2011 | 07:49 PM
97western haulin's Avatar
97western haulin
I got up this morning started my truck like normal to warm it up. It ran for about 15 minutes and then just cut off. I tried to restart it and it would crank and crank and crank never fire off and run. also the wait to start light doesnt come on anymore. I was told could be an issue with the injector relay, i checked it and it was fine. could it be the IDM has gone out?
Old Dec 10, 2011 | 08:21 PM
427 fordman's Avatar
427 fordman
Fuse 22 under the hood. Replace it and unplug your fuel bowl heater, middle connection on the fuel bowl. It most likely shorted out, runs on the same fuse as the pcm. Replace if you wish, most just leave it unplugged unless you live in real cold.
Old Dec 10, 2011 | 10:18 PM
oldbird1965's Avatar
oldbird1965
injector relay?
Old Dec 10, 2011 | 10:55 PM
fordpride's Avatar
fordpride
Old Dec 10, 2011 | 11:08 PM
97western haulin
thanks, i will try that first thing in the morning.
i meant the IDM relay
Old Dec 11, 2011 | 07:27 PM
97western haulin
That was it. thanks for the help. I happened to find where the wires were exposed and taped it up just so i can have it when we do have the real cold weather down here.
StillNotKing
21
Sep 28, 2021 08:19 AM
magicsac1366
Jan 8, 2014 04:57 PM
bigdaddys99
Aug 24, 2010 03:31 PM
jhand124
Dec 10, 2007 09:38 AM
vancouverpower
Jan 18, 2005 02:29 PM
