Blue Smoke When Cold
Old Dec 11, 2011 | 05:30 AM
wulfman's Avatar
wulfman
Look mine does the same thing when it gets cold you see a little blue smoke on start up seems to do it every winter . It does not do it when its warm maybe it is my turbo seal but only when its cold. So after a few years now i don't pay much attention to it.
Old Dec 11, 2011 | 09:09 AM
BobsF350's Avatar
BobsF350
i had the same problem.Turned out to be the copper crush washer for the injectors leaking.Tuned youll have more cylinder pressure and injector timing and much more noticable than untuned.
Repair was 30.00 in parts and about 5-6 hours of my time
Old Dec 15, 2011 | 04:20 PM
204Superduty's Avatar
204Superduty
Thanks for the quick replies, i will have to look into those things. Any suggestions for egr delete kits?
Old Dec 15, 2011 | 05:12 PM
9228.bobcat's Avatar
9228.bobcat
I have a sinister. works great. Make sure you have a programmer that deletes it out of your pcm.
Old Dec 15, 2011 | 05:27 PM
2006lariat's Avatar
2006lariat
I did not know this was a problem. My truck has been doing this for 2 year's. I actually thought this was what wet stacking is? Engine not hot enough, to burn all the fuel, and thus spitting it out the pipe. Is this wrong? (I never noticed it when I had the cat on, but whe the Kitty fell to it's death............I thought the truck was grieving)
Old Dec 15, 2011 | 09:38 PM
dukie1877's Avatar
dukie1877
its not going to hurt anything if you dont have a programmer to delete the egr. Leave the egr plugged in its important according to cheezit for some reason the rpm speed of the fan slows way down when the egr is not present. So you can delete the egr but your going to want to leave the egr either in the hole it was in where your new cover plate is going to be or use the cover plate and find a spot for it on the top of the engine.
Old Dec 15, 2011 | 10:55 PM
steelhead2's Avatar
steelhead2
Hunting last year and cruising the roads my truck would smoke blue when i stopped. Kinda like wet stacking. Its low combustion temps coupled with fuel oil burning. Thought it couldve been a turbo seal but it wasnt. Also egr valve was dry. Blue smoke doesnt always mean oil. Next time you go by a truck stop and theres trucks there idling that blue smoke you see isnt engine oil, its fuel not being burned and pushed into the exhaust where it creates blue smoke. Or, you could have an injector thats not quite right.
holleyjr85
Nov 26, 2011 08:26 PM
7.3PSD
Jan 25, 2007 08:10 AM
uvbensmoked
Oct 4, 2006 02:36 PM
rprhyno
Jul 27, 2005 06:50 PM
mcn420
Sep 22, 2004 09:58 PM
