carb?
Old Dec 9, 2011 | 11:00 PM
bigfoot7180's Avatar
bigfoot7180
carb?
i have a 78 f150 with a 74 351c 2v in it.it has a stock 2bbl on it.i have a 4bbl q-jet and an adapter will i get better performance from the q?i know with an adapter i wont get the full potential but would it be better than the stock 2bbl?thanks
Old Dec 10, 2011 | 04:22 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Best way to tell is to get some gaskets and bolt it up; since you have all the parts. If you don't like it you can change back.
If you have a automatic the only real fitment issue would be the kickdown linkage.
You can use a rubber fuel line till you decide and the throttle linkage should be close; you might need to adapt a linkage pin onto the carb throttle arm.
The choke can be just electric for testing.
Old Dec 10, 2011 | 01:17 PM
bigfoot7180
thanks old style.i was just curious tkif anyone new if itd help or hurt performance
Old Dec 10, 2011 | 10:37 PM
bigfoot7180
i guess ill try old styles idea since no one else has used a 2bbl to a 4bbl adapter to let me know if it helped or hurt their performance thanks guys
Old Dec 12, 2011 | 02:31 AM
7Ford6's Avatar
7Ford6
My guess is that with the Qjet on the 2 to 4 adapter it will help your performance from stock, as the Qjet will only flow what is demanded of it... Qjets are optimized for each specific engine size, Find one was used on a similar engine size or larger and you should have a good start... I custom built one for my application, a 390... but with a 4 hole adapter to a 4 barrel manifold... Which would be the better manifold for your app.. over the 2 to 4 adapter...
I used Doug Roes book and Cliff Ruggels Book and Parts... and all I can say is WoW.....
http://www.amazon.com/Rochester-Carburetors-Doug-Roe/dp/0895863014
Cliffs High Performance Quadrajets :: Qjet Carburetor Rebuilding Book
Ram Air helps as well....
Ended up using one of these with the correct height base plate... and with 4 inch dryer duct hose routed to the outer corners of the engine bay just over the front radiator support edges, held on with tie wraps and a slight hood pressure... lol....
Ram Air Box
This one can be sealed water tight for underwater apps... Didn't set right in my engine bay so I used it on another car of mine where it fit perfect
Schmidt Motor Works Ram Air Cleaner
and then there is always Spectra...
Spectre Performance - Official Site
Old Dec 12, 2011 | 04:51 AM
bigfoot7180
thanks 7ford6 the qjet is off a 350 that had been bored 30 over.it ran good on it so i figured it would do good on my 351c.other than i cant afford an intake right now.but i have the adapter so ill give it a shot.
Old Dec 12, 2011 | 05:09 AM
7Ford6's Avatar
7Ford6
Just brush up the the tuning side and you should be good to go... A couple of refresher links....
Setting Idle Mixture The Right Way
How to Use and Interpret a Vacuum Gauge
Keep us informed on the final outcome... Excellent Test.....
Old Dec 12, 2011 | 06:03 PM
bigfoot7180
supposed to get 65 wendsday so i might try to get it put on thanks for the info.
Old Dec 15, 2011 | 05:02 PM
7Ford6's Avatar
7Ford6
How's it working out for ya ???
Old Dec 17, 2011 | 08:02 PM
bigfoot7180
sorry 7ford6 i threw my back out and havent been able too install it yet ill update you as soon i can
Old Dec 18, 2011 | 04:45 AM
7Ford6's Avatar
7Ford6
I know that feeling... Take your time... Light swimming, floating in the water, then the jacuzzi, and then the steam room have always helped me work the kinks out, then sweet 'ol time, to let the muscles mend......
Do it when your ready...... Make's it a lot more enjoyable test when your feeling well...
Josh McReynolds
Dec 1, 2016 05:14 PM
Jag Red 54
Sep 14, 2012 12:45 PM
teederj2002
Dec 9, 2005 05:48 PM
19gator55
Mar 13, 2004 12:24 AM
stgdive
Nov 19, 2003 03:20 PM
