need some knowledgeable opinions
Old Dec 9, 2011 | 07:11 PM
n4gnr's Avatar
n4gnr
My 66 f-100 has a problem with the headlights. After turning on the headlights,, after 10 minutes or so,, they start blinking on/off I may go 4 miles and no problem,, then here they go again-off/on/off/on Sometimes my dash light goes out also. I thought maybe it was the dimmer switch in floor. But when the dash lights went out,, I feel sure its the headlight on/off switch. Must I use an original ?? Or is there an updated one that will work(modern). Thanks for any input...Dan
Old Dec 9, 2011 | 08:32 PM
66f-100's Avatar
66f-100
The headlight switch is shot. When they are worn out, they overheat and trip the circuit breaker in the switch causing the lights to blink. You can get a new one at any auto parts store.
Old Dec 9, 2011 | 10:58 PM
SuperSabre's Avatar
SuperSabre
I agree that your problem is probably the light switch. All Fords of this vintage suffer from the same thing. My '65 Galaxie had the problem in '67!While it's true that you can probably get a replacement at any auto parts store, I seem to recall hearing about "issues" with some aftermarket switches. NPD has some NOS Ford Motorcraft switches that sell for about $41 (see page 14 of Catalog #8). There are probably several switches that fit, and if I remember correctly, the newer they are, the more likely they are to withstand higher loads. The one NPD sent me is P/N D3ZZ-11654-A. Good luck.
Old Dec 10, 2011 | 03:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by SuperSabre
NPD has some NOS Motorcraft switches. The one NPD sent me is P/N D3ZZ-11654-A
D3ZZ-11654-A (replaced C5DZ-11654-A, C5TZ-11654-A, B & C) .. Headlamp Switch Kit (Motorcraft SW-1245) / AVAILABLE from Ford
MSRP: $50.18 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $33.12.
Applications: 1965/66 F100/1100 // 1965 Mustang from 8/17/1964, 1966 Mustang / 1965/69 N/NT/T500/1000 / 1965/70 Falcon / 1965/71 C Series Tilt Cab / 1966/76 Bronco & 1977 Bronco before serial number C25,000.
1967/69 F800/1000 / 1967/72 F100/750 / 1970/71 Maverick/Comet, 1972 Maverick/Comet before 1/3/1972 / 1971/72 Mustang.
Note: Even though this switch has a 1973 Mustang part number prefix (D3ZZ), it does not fit a 1973 Mustang!
Old Dec 10, 2011 | 11:58 AM
William's Avatar
William
Hot light switch
Replacing the switch is a good idea. But, have you installed an upgraded light system, like halogen bulbs? These systems tend to draw lots of current through these switches and may overheat them. Also I have found loose connections at the switch plug will cause overheating. Rotten and corroded bulkhead connectors can also be the problem. So the switch is responding to a high heat/amperage and actually doing what it is supposed to do---shut down the circuit. Use plenty of dielectric grease on the plug so that it seats completly on your new switch. To remove the switch reach up under the dash and feel for a small spring loaded button on the top of the switch. Push the button and gently pull the switch **** out, then unsrew the bezel and drop the switch out and down. Now is the time to unplug it. Install is the reverse of removal. There was an article in the tech section a few years ago that may still be there called whiter whites brighter brights that details how to install bosch relays to improve power to the lights and reduce the load on the switch. Good article!
gemutlich
May 9, 2017 09:24 PM
duphofff
Sep 6, 2015 05:43 AM
johnmel59
Jun 30, 2013 06:48 PM
Alex from GA
Oct 14, 2011 07:05 AM
civicmindeddogooder
Feb 15, 2011 11:31 PM
