ran rough now no start
Old 12-28-2014, 07:11 PM
BigRed7.3l's Avatar
BigRed7.3l
BigRed7.3l is offline
So I have about 200k miles and my truck ran great, no hiccuping injectors or anything and then I got on my road going up hill and it lost all power and started running like garbage. I got it home and for a bit I could get it started but it doesn't go anywhere and it runs very rough.
Now I can't even get it started.
I find it hard to believe that its injectors because it wouldn't just all of a sudden do that.
I'm thinking Hpop or IPR, something like that. But what I'm wondering is, is there something I can buy that'll run a full diagnosis on the truck even though it doesn't start ? Like pressure readings of stuff?
Old 12-28-2014, 07:41 PM
JT250's Avatar
JT250
JT250 is offline
Auto Enginuity from RiffRaff is what most of us use. It is some money up front but will save you in the future.
The easiest thing to start with if you don't have a diagnostic tool is the CPS. If you haven't replaced the Camshaft position sensor it could cause an instant failure like this. You could also verify that your fuel pump is working by listening to it when you turn the key on below the drivers side door in the frame rail. You can also look at the tin nut on the IPR and make sure it is there and tight.
There are a lot of no start threads . start reading up. You will most likely find answers to any questions you have.
Old 12-28-2014, 08:13 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
How much fuel is the gauge showing?
Old 12-28-2014, 08:18 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
Could be a fuel starvation problem. How much in the tank when this started? Have you ever done the in tank mods? (edit..dang Pika beat me to it)
How's your oil level?
Do you use an android phone. You can get an app and an adapter to monitor pressures etc. Search "torque pro" on the forum search and read up/
Old 12-29-2014, 09:46 AM
BigRed7.3l's Avatar
BigRed7.3l
I have a full tank, no mods done to the tank, and I have replaced the CPS about 2 years ago but I'll see if that's the issue. I plan on buying Ae for sure.
And yes I use an android.
Old 12-29-2014, 10:14 AM
AllaboutMPG
Did you get a chance to check your oil level?
Open the drain valve on the back of the fuel bowl and turn key on. do you get a strong stream of fuel out of drain. Will come out under the engine near front axle middle so have a drain pan or do it in a place fuel can run out.
Old 12-29-2014, 10:25 AM
AllaboutMPG
Get a blue tooth OBDii adapter and the Torque pro app for your phone. you can monitor pressures and voltages.
Old 12-29-2014, 10:49 PM
BigRed7.3l's Avatar
BigRed7.3l
oh right i did forget to mention my oil level was fine. and ill take a look at my fuel pressure through my fuel bowl tomorrow morning. but my fuel pump is brand new [well 6 months old lol]
thanks for the heads up on the bluetooth obd2
Old 12-29-2014, 11:00 PM
BigRed7.3l's Avatar
BigRed7.3l
and wow! thats a pretty cool app btw! i wish i knew about that sooner. $5 for the app and $8 for the bluetooth obd2 port!
79OldBone
17
03-28-2013 07:33 AM
jayc3169
08-06-2012 06:37 PM
hi-jacker
07-19-2011 07:27 PM
gwebel
06-25-2007 10:16 AM
putzhall3
03-11-2007 02:29 PM
Quick Reply: ran rough now no start
