timing issues
Old Dec 9, 2011 | 03:32 PM
eric77crew's Avatar
eric77crew
timing issues
Hey. I have a 400 in my 77 crewcab and I'm curious to know what the timing should be set at. It has the vacuum advance on the distributor and its duraspark and when I time it. Do I keep the vacuum line on or off the dis. When I time it. Thanks much for your help.
Old Dec 9, 2011 | 05:54 PM
Sleepy445FE's Avatar
Sleepy445FE
The 400s I've timed seem to like about 34° total. You unhook and plug the vacuum adv. Then put a timing light on it and rev it till it stops advancing, usually somewhere around 3000rpm. That is your total timing. Rotate the dizz until that total number is 34° and it should be good to go.
Old Dec 9, 2011 | 06:15 PM
eric77crew's Avatar
eric77crew
OK cuz I've never timed an engine. I timed by ear and by driving it and she's Bern running quite well but I would lime to know exactly
riverguideguy
May 13, 2013 09:33 PM
dyoungen
Mar 21, 2013 09:51 AM
hooperdoski
30
Oct 19, 2012 04:07 PM
towtruck
13
Dec 14, 2004 12:12 AM
