carburetor
Old Dec 9, 2011 | 01:07 PM
79xltcustom's Avatar
79xltcustom
carburetor
Can anyone tell me what is needed to change my 79 f250 with a 400 from a manual choke back to the automatic set up? The p/o changed out the choke and put a manual one on it and I'd like to change it back, but I'm not sure what all is replaced when a manual one is put on. Any help would be appreciated, thanks
Old Dec 9, 2011 | 03:15 PM
4x4 Bart's Avatar
4x4 Bart
You need the heat tube coming from the exhaust manifold. The black cap and coil along with the correct wire connected for the heated element.
Old Dec 10, 2011 | 05:34 AM
dulockdrumheller's Avatar
dulockdrumheller
I needed to subscribe to this. I need to know where I can get that heater tube at, broke mine doing some maintenance. I'll try to check up from time to time but not sure how to find this thread again.
Old Dec 10, 2011 | 06:40 AM
armstrongfordtrucks's Avatar
armstrongfordtrucks
There is a replacement tube kit at the autoparts store, try napa. You're in texas, you might find a good one in a wrecking yard. That way you can get the part in the intake also.
Old Dec 10, 2011 | 08:02 AM
fmc400's Avatar
fmc400
MSEE
Agreed, Dorman makes a kit. You can also make one out of brake line and high-temperature sheathing.
jb85302
Dec 12, 2009 05:08 PM
JimBrown
Apr 15, 2008 04:19 PM
garbz2
Jan 18, 2008 01:00 PM
ole yeller 1978
May 13, 2006 10:16 AM
robv60
Oct 8, 2004 04:02 PM
