Headlight upgrades. HID?
Old Dec 11, 2011 | 07:29 PM
73 ford guy's Avatar
73 ford guy
Originally Posted by 460me
You can do relay's or upgrade your alt to the 3g 130amp.That will make them lights bright.
I have a 160 amp alt that was built locally and he claims it does 100 amps at idle. They specialize in alternators..
Old Dec 12, 2011 | 08:49 AM
psquare7575's Avatar
psquare7575
Originally Posted by Bullitt390
I don't have a before shot against a wall, but I could take one for an after.
Josh
Yeah, if you could. I'm curious on the light beam and cutoff points
Old Dec 12, 2011 | 09:16 AM
buttwheat's Avatar
buttwheat
Originally Posted by i-w
i use sylvania silver stars. made a huge difference. so bright i get people coming the
other way flashing me to turn down the high beams.
Nothing to be proud of.
Old Dec 12, 2011 | 10:25 AM
psquare7575
Definitely nothing to be proud of. I have IPF housings with 80/100w bulbs and a relay harness. the IPF housings have nice cut offs, and I do not get flashed at all.
Old Dec 12, 2011 | 03:09 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Not sure I would go any further than just swapping to the newer crop of sealed beams, along with adding the relay harness. These newer sealed beams are much brighter than the original headlights, but they also draw a bit more power. As such, the relays take the load off the headlight switch, typically extending it's lifespan.
Sealed beams may be "old school technology", but the newer plastic lenses on the replaceable bulb headlights get foggy/cloudy over time, dimming the total output of light. With a sealed beam, you always start off with fresh lens.
Old Dec 12, 2011 | 06:11 PM
79FordBlake's Avatar
79FordBlake
Unless you are buying junk lights most aftermarket lights for these trucks have a glass lens.
Hella lights with sylvania xtravision bulbs is as bright as you will ever need.
Old Dec 12, 2011 | 06:18 PM
79FordBlake
You do know that you could be the cause of someone's death?
It is getting more and more common for people not to adjust their lights correctly.
98woody
Jul 30, 2015 07:08 AM
Gage2502
Jul 7, 2012 09:49 PM
Chance_Thomas
Apr 2, 2009 07:07 PM
67speeda
Electrical Systems/Wiring
Feb 2, 2007 06:46 PM
