HID conversion needs help asap! (noob)
Old Feb 1, 2007 | 08:57 PM
67speeda's Avatar
67speeda
I have a 04 silverado SS and just ordered 8000K HID's for it. I want to order another kit for my dad's 02 banks PWSD F-250 crew SD. he has rather odd lights in the front. his are set back, not smooth like most other's. they do not take replacement bulbs, they take new headlight assemblies. I have only seen a few others like his. (looks terrible)
i wanted to convert to the cleaner style and install the HID's in them. All i can find are aftermarket ones and idk if the OEM style bulb will go into them and idk what a projector, angle eye, blacked out, crome housing will do.....
help PLEASE!!!!!
<----want this type, with replacement bulbs
has those kind of headlights (not grill ones, bad pic but all i could find)
Old Feb 1, 2007 | 11:51 PM
SPL Tech's Avatar
SPL Tech
So what are you asking? Are you asking if someone makes a HID conversion kit for vehicles with fully sealed headlight assemblies? If so the answer is probaly not. I have never seen one anyway.
Old Feb 2, 2007 | 12:46 PM
sean1997's Avatar
sean1997
The XL trucks come with the old style sealed beam headlights. You can buy the parts (header panel and headlights) from Ford to convert the old H4 style bulbs to the new H13 (9008) style bulbs. You will also need a new wiring harness or I think Ford may sell an adapter. Here is a link to one wiring harness:
http://www.puredieselpower.com/catalog/9008-headlight-heavy-duty-wiring-harness-upgrade-p-620.html?osCsid=3u8gomkdad994sqdf4aeecsl43
Once you get the H13/9008 bulb connectors you should be able to find an HID kit for it. You can search in the Super Duty And Heavy Duty forum for more information on the '05-'07 headlight conversion. You may not need the wiring harness if the HID kit includes a separate harness, but at least this would give you the headlights that accept the H13/9008 bulbs.
-Sean
Old Feb 2, 2007 | 01:13 PM
sean1997's Avatar
sean1997
Here is a link for a place that has HID kits for the H13/9008 bulbs:
http://www.hidfoglight.com/productsAndServices/hidRetroKits.html
It says they have kits for the H4 bulbs, but it is probably for the replaceable style bulbs and not the sealed beam style.
-Sean
Old Feb 2, 2007 | 04:44 PM
67speeda's Avatar
67speeda
sorry
i need to conver the whole headlight assembly to the smoother one in the first pic. i have the headlights in the bottom picture. This way i can install HID's
HID kit has own harness
want OEM but aftermarket has many different types. would a aftermarket projector headlight assembly work?
Old Feb 2, 2007 | 05:35 PM
SPL Tech's Avatar
SPL Tech
Sorry I dont know. I have never done any light work on that vehicle. Good luck.
Old Feb 2, 2007 | 05:51 PM
67speeda's Avatar
67speeda
looks like i am going to need the good luck! lol
at least my truck will have hid's lol
Old Feb 2, 2007 | 06:12 PM
sean1997's Avatar
sean1997
Read these threads in the Superduty forum (search for headlight conversion):
https://www.ford-trucks.com/forums/4...n-my-01-a.html
https://www.ford-trucks.com/forums/5...-question.html
The second thread lists the part numbers as:
"the part# for the 05-07 header panel is 5C3Z-8A284-AA. you will also have to change the wiring harnesses bcause the new housings use different bulbs. part # for the housing is WPT-793 or 3U2Z-14S411-FKAA (you'll need 2 of them)."
The headlights in the top picture are the '05-'07 style. The headlights in the bottom picture are H4 sealed beams found on XL trim level trucks. To replace the H4 sealed beam lights on your truck you can get the '05-'07 OEM headlight assemblies from Ford. The '05-'07 headlights take the replicable H13 bulbs (also called 9008 bulbs). You have to either modify the '99-'04 header panel to accept the '05-'07 headlights or you can order a new '05-'07 header panel.
Many people also upgrade to the '05-'07 grill and front bumper when doing the headlight swap, but it is not required. Note though, the '05-'07 grill will not fit a '99-'04 without either changing the bumper or modifying the '05-'07 grill.
You may also be able to use the XLT trim style headlights, so read this thread in the Superduty forum:
https://www.ford-trucks.com/forums/5...le-lights.html
-Sean
Old Feb 2, 2007 | 06:46 PM
67speeda's Avatar
67speeda
i want the xlt/lariat lights of the same year. i just want to be able to change the bulbs and not the whole unit. this way i can do a hid swap.
looks like i can kepp the corners i have now
