1940 Ford Pickup.....Ashtray?
Old Dec 9, 2011 | 11:00 AM
jarheadd87's Avatar
jarheadd87
Hello all.....I am restoring a 1940 Ford Pickup. On the dash between the defrost vent holes is what appears to be the cutout for an ashtray. It is definitely factory....not an aftermarket cutout job. It appears the cab may not be from a 40 Ford as the fender bolt holes do not match up....additional holes were cut to make it fit. Does anyone have any idea what year Ford put an ashtray in the dash of a pickup? It would have been between 40-47. If I can't locate an ashtray I will just weld it up and leave it at that.
Old Dec 9, 2011 | 06:58 PM
newold46's Avatar
newold46
If you look here, you will see they did put in an ashtray.
Page 11 I think it was...
Old Dec 10, 2011 | 04:37 PM
46fordtruck's Avatar
46fordtruck
Jarheadd87, welcome to the site, hopefully you can find the answer here.
The only ashtray I have seen, from the factory or Ford installed, was mounted under the dash, under the glove box. I've never seen one that was mounted on the dash up near the windshield. If you can get a pic of the hole in the dash that might help.
Old Dec 16, 2011 | 06:57 PM
5 Star's Avatar
5 Star
1947 Factory Ash Tray
Here is a Factory Ash Tray, mounted to the left of the glove Box Door under Dash.
Also the 1940 Cab had a filler plate in the center of the Dash face with the Ford script on it.
Looks like it may have been used for a Radio.
txskinney
1947 and Older Ford Trucks
Jun 6, 2016 07:31 PM
autoxtech
Dec 23, 2012 11:16 PM
v8xploder
1966 - 1977 Early Broncos
Sep 7, 2007 05:35 AM
Jonas1022
Aug 2, 2007 01:25 AM
PRyan1983
Apr 2, 2003 07:37 PM
