Testing the CKP and CMP circuits
Old Dec 9, 2011 | 09:33 AM
fixxxer-upper's Avatar
fixxxer-upper
FTE Fan
I would like to check the resistance on the CMP and CKP circuits. What pins in the PCM plug on the FICM would I need to check, and what range of readings on the meter would be considered good/bad?
Thanks.
Old Dec 9, 2011 | 09:43 AM
joetech's Avatar
joetech
The new way GM recommends testing suspect circuits is a loaded voltage drop test. An ohm reading of less than 1 ohm is good. Cam sensor is 31 and 43 Crank sensor is 30 and 41.
Old Dec 9, 2011 | 10:04 AM
fixxxer-upper
FTE Fan
Thanks. I will check them out when I get home tonight.
Old Dec 9, 2011 | 06:17 PM
cheezit's Avatar
cheezit
the should really be check on a 2 channel osciliscope. we are more worried about timeing and patterns then anything else
bobber1
1983 - 2012 Ranger & B-Series
32
Aug 26, 2025 11:54 AM
nothingbutford
Oct 17, 2024 07:44 PM
raptor2005
Jan 20, 2013 03:30 PM
Critterhunter
Feb 1, 2006 08:01 PM
kyles94
Sep 26, 2005 08:27 PM
