anyone put a front hitch on a 1984 4.9 4x4 f 250 all i can find is this hitch here Warn 25862 Hitch | Auto Parts Warehouse but seems pricey and doesnt look like the correct mount
What are you trying to accomplish? I have a ball mounted on the front bumper using the license tag holes, and that allows me to move my boat around easily. But, are you looking for a serious hitch?
This is just my opinion, so take it for what its worth. So few people want a front hitch compared to a rear mount hitch, that they will naturally be a lot more expensive. Since these hitches are used only to move trailers around at very slow speeds and for short distances, most people make their own.
well i saw you can get one for my truck and its like 300 $ and i just want to use it to support my cargo rack for going to the beach so i can also tow say a boat. the one they offer is different then i think it would work for my truck..
Sounds like it needs to support a couple hundred pounds - right? My bumper-mounted hitch easily does that 'cause I use it as a step to climb up under the hood. I could send you a picture of it if you'd like.
yes if you could,,,and if its attached to the frame at all take a picture of that too please?
Yes. But I tried selecting my make 1984 ford f250 4x4 and I can only get as far as a jeep. At the top of the thread I posted one for a warn hitch but unsure if that's how it would bolt
I too tried it, try giving them a call. They may beable to build it. The had then listed down to 92 on the first site I posted. I know the 1980-1991 had the same frame. In 1992 the changed the front where the bummper mounts to an acourdian style.
Is there a custom hitch and trailer builder in your area? I have one back home that could fab up anything, and was not too expensive either. You could almost guarantee that it would be stronger than anything that you could buy.
no one i can really think of, only a few steel places... but i have a welder and if i attempted id try it.. i was hoping to get a few ideas
I'm still not exactly sure what you want it to look like, but if you had something like the L piece that makes up my hitch, only long enough to come down below the bumper, and welded a piece of square tubing to the bottom you could slide a draw bar in it.
Or, a piece of plate that would fit in the license plate area and long enough to come to the bottom of the bumper. Weld a piece of angle to it at the bottom, and then weld a piece of square tubing to the angle.
As you can tell, I'm not good at describing it, but I could draw it up if you can't "see" it.
