06 F150 Leveling Kit ?
Old Dec 8, 2011 | 10:12 PM
Desert 4x4's Avatar
Desert 4x4
Hello Guys, I am looking at the Bilstein leveling shocks for a 06 F150 2wd. I noticed that there is a different part number for the 2wd and 4wd trucks front and rear shocks. What is the difference between the two, is the shock valving different? The truck is a supercab shortbed with a campershell. I wanted to add the leveling kit the front and possibly add a 1 to 2" block to the rear to keep the stock stance but have more wheel travel. would this work I know that the leveling kit will not serve a purpose with the block in the rear just looking for a little more ground clearance for the 2wd.
Thanks for any info Desert 4x4
Old Dec 9, 2011 | 06:07 AM
Coskid's Avatar
Coskid
Leveling kits don't really give you more travel they just add some room for the tires. Also with the lift you already have do you have extra springs in the back or a block already?
If it is a block already then most would not recommend adding another block as it can become unsteady.
Old Dec 9, 2011 | 11:20 AM
Desert 4x4's Avatar
Desert 4x4
no rear block right now. I am thinking about adding a 4x4 block to the rear and a 2" leveling to the front.
Does anyone know the part number for the 4x4 rear block for a supercab short bed
Old Dec 9, 2011 | 10:03 PM
Coskid's Avatar
Coskid
Any rear block designed for a F150 will work there is no difference between super cab or super crew blocks so they should be easy to find.
Old Dec 9, 2011 | 11:47 PM
Desert 4x4's Avatar
Desert 4x4
okay thanks
Old Dec 11, 2011 | 07:57 PM
Coskid's Avatar
Coskid
Was thinking about this earlier today and while part of what i said is correct part is not. The rear blocks should be easy to find but you just have to make sure it is designed for an 04-05. In 06 they made a change to how the blocks get secured so they would not work on your rig.
Old Dec 11, 2011 | 08:02 PM
Desert 4x4's Avatar
Desert 4x4
okay i will look into it. I may just do the bilstein leveling kit
Old Jan 2, 2012 | 05:47 PM
tpeek's Avatar
tpeek
2007 XLT crew cab 4X4, 3.73 gear
When I bought my truck over a year ago, it was already leveled, looks great with the 2" lift. Question is: How will the front lift affect fuel mileage?
Thanks
Old Jan 3, 2012 | 06:24 AM
Coskid's Avatar
Coskid
It depends really on many things but most the tires you have on the truck. When I installed my kit I really didn't notice the loss of fuel mileage. I might have loss 1 MPG but that's nothing and could easily be something else.
Big Hurt
Jan 28, 2016 01:18 PM
B_Thompson
Apr 27, 2009 07:52 PM
AzBaddBoy
Jan 16, 2006 02:08 AM
