Cab Light Strobes
Old Dec 8, 2011 | 05:47 PM
Rose Clifford's Avatar
Rose Clifford
Cab Light Strobes
Is there a LED/Strobe kit available for a 1997 OBS F250? Keeping the stock look is a must too. I've looked around on the goog but can't find anything that keeps the original look.
Thanks
Old Dec 8, 2011 | 05:56 PM
Diesel_Brad's Avatar
Diesel_Brad
Highly doubt it. There is barley enough room for the 194 bulb that is in there. Unless you can find a 194 strobe bulb
Old Dec 8, 2011 | 07:01 PM
thechief66's Avatar
thechief66
Probably illegal, too. I know they are in my state...
Old Dec 8, 2011 | 07:13 PM
danr1's Avatar
danr1
How about something like this,
Amazon.com: 10x 194 168 2825 5-SMD White High Power LED Car Lights Bulb by AGT: Automotive
Used with one of these,
LSC-100B Continuous Pulsing Strobe Module
Old Dec 8, 2011 | 07:25 PM
IowanStraight6's Avatar
IowanStraight6
Danr1 you are the man!!!
Old Dec 8, 2011 | 08:02 PM
Diesel_Brad
Didnt even think about the legal issues.
But now that you mention it, it would be illegal here too. Because in order to make it strobe, it would have to out until it does strobe. Which would mean, the bulb does not light and that is a ticket able offense
Old Dec 8, 2011 | 08:11 PM
IowanStraight6
Iowa strobes are legal as long as there not blue and red
Old Dec 8, 2011 | 08:13 PM
Diesel_Brad
But how are you going to make a single filament bulb strobe?
To the OP here are some LED cab lights that Flash
AtomicLED.com - Custom LED running lights for trucks
Old Dec 8, 2011 | 08:21 PM
danr1's Avatar
danr1
Was amusing the OP wanted them for off road use, plowing parking lots perhaps?
If so why not wire them in such a way that they stay on when on the street and power routed through the strobe control when need them to flash?
Single pole double throw switch, one circuit direct to lights (normal function "on" when headlight/running-light is on), second circuit from same switch routes power through SC to lights so they flash.
Could easily be set up to also flash without truck lights on, just a matter of using the right switch/circits for the task.
Old Dec 8, 2011 | 09:19 PM
Rose Clifford
The atomic's would be perfect except they don't make them for OBS trucks.
Old Dec 8, 2011 | 10:23 PM
DasCheckers's Avatar
DasCheckers
I'm installing them into my clearence lights as well. My strobes are used for night work as a construction worker, and also as emergency lights.
Old Dec 9, 2011 | 06:00 AM
Rose Clifford
You're putting Atomic's on your 97? Are you using the kit for the 98+ Super Duty's?
meier63
Jan 24, 2018 11:07 PM
Codyaye
Feb 19, 2017 08:13 PM
cashman2310
Sep 27, 2016 08:41 AM
Firekite
May 18, 2015 02:50 PM
mean green2
Jul 14, 2005 10:26 PM
