1978 - 1996 Big Bronco
Quick question?
Old Dec 8, 2011 | 05:10 PM
jahollis2380's Avatar
jahollis2380
Quick question?
In my 89 bronco with the 4.9, five speed and manual t-case. The tranfer case went out. The front axel doesnt spin. Im assuming this means its a chain driven case? The 2h works, is it ok to drive it till i get it fixed? I am sorry that i do have a model number for the t-case, im looking for it now.
Old Dec 8, 2011 | 05:22 PM
Encho's Avatar
Encho
The Southernmost Mod
Your truck probably have a BW1356 tranfer case, try to disengage and you should be able to use the truck with no issues whatsoever, you just won't have 4WD. If you're low on funds, go to a junk yard, you can find plenty of those for $100-200.
Old Dec 8, 2011 | 05:45 PM
jahollis2380
It is disengaged. I think it got hung up in 4h. Is there a quick way to tell which t-case it is? I couldnt find a tag on it
Old Dec 8, 2011 | 06:35 PM
njneer1's Avatar
njneer1
I can guarantee it's a Borg Warner 1356.......go to Jeff's bronco graveyard and compare
Old Dec 8, 2011 | 08:46 PM
jahollis2380
Oh! Never thought of that! Are they difficult to repair?
Old Dec 8, 2011 | 09:10 PM
Edgethis's Avatar
Edgethis
Easier to replace. They are plentiful in junkyards or craiglist.
Old Dec 8, 2011 | 10:10 PM
njneer1's Avatar
njneer1
Easy to fix unless the chain busted the case......about $250 for bearings and seal with chain........long as you don't need any other hard parts
Old Dec 9, 2011 | 07:13 AM
jahollis2380
Ok. At highway speed when i mash the clutch, you can hear and feel it jaring back there! Is it safe to drive? It will be next thursday before i can work on it
Old Dec 9, 2011 | 07:37 AM
fast_st's Avatar
fast_st
It may not be a problem with the chain etc.
That model transfer case uses a chrome steel shaft that runs through a simple seal and into the case. This shaft operates the sector gear. If water gets past the seal, the magnesium case dissolves and lets the sector gear **** to the side rendering some or all transfer case functions inoperable. If it gets bad, the transfer case will drop into neutral until you stop and cycle the shift lever. A machine shop can re-bush the case but I ended up replacing the case half and the planetary around 250k miles.
Old Dec 9, 2011 | 08:39 AM
jahollis2380
Ok. Well crap! I was hoping it was a chain breaking. But this morning it jared again and i knew it was something else.
Old Dec 9, 2011 | 08:59 AM
fast_st's Avatar
fast_st
One more thing, when you're in there, if you have someone with a mig welder handy, add a 1 inch wide tab to your oil pump arm, it tends to wear a notch in the case half.
If you have time, you can fix the case half with jb weld to keep the shaft in the right position. Dig out the corrosion and put some jbweld in the gap, lightly grease the sector shaft, install and hold it back tight with wire. After 24 hours, remove the sector shaft, put in a new seal and you're good for a few years.
Old Dec 9, 2011 | 10:14 AM
AbandonedBronco's Avatar
AbandonedBronco
There were only two models available, NP-208 or BW 1356 (in later year Broncos)
The NP has a big starred circle on the case towards the rear with an NP in the center. It stands out.
Old Dec 9, 2011 | 11:19 AM
jahollis2380
Fast_st, thank you for that info. Thank all of yall. I believe ill just replace it, then rebuild the old one. Is there a stronger t-case i could look for that wont be a total cluster to pit in?
Old Dec 9, 2011 | 09:30 PM
njneer1's Avatar
njneer1
I could be wrong but I don't think anything fits perfectly
Old Dec 12, 2011 | 07:46 AM
fast_st's Avatar
fast_st
Well your stocker has lasted this long and likely you're not dealing with a strength issue, just wear and tear and possibly corrosion. Transfer cases are super simple, to work on but yeah, swap in a used one would be fast and cheap, make sure the shift arm has zero wobble in it.
