I forgot one post I think here. He claim it cost $15 dollars MORE a months in electric if plug overnight. Those block heater on 7.3L powerstroke I heard 1000 or 1500 watts.
I'm going to assume the 7.3L uses the same style/wattage heater as the 6.0L since Navistar built both. Which would be a 1500 watt heater. Maybe they do use an extra $15 a month, but how much diesel would you burn waiting for the engine to warm up? I'm willing to beat more than $15 a month.
It first time I had powerstroke in winter. Last year I had idi 6.9L that wasn't FUN to start. Plug block heater for 2 hours then Pray it would start. There couple times it won't start. I end go crazy and use plumber torch heat on bottom of exhaust manifold. Leave heat for about 5 mins. Then jump in truck and crank it start.
My plan this winter I wouldn't plug if it really cold then plug for 1 hour then start. Idle 2-3 mins then drive slow until engine temp go up.
That's interesting, and something I never really considered. How much electricity does the block heater draw? I didn't think it would draw enough to really make much difference in the electric bill.
It would be like burning 10 or 12 100 watt lightbulbs for whatever time you have the block heater energized (somewhere around 1000 or 1200 watts...don't remember the specification)...buy a heavy duty timer for around $10 or so and set it to turn on for two to three hours before your anticipated start time. If you had a set of guages you could monitor your coolant temps and adjust the timer duration for more or less depending on your ambient temps in you area. Good luck.
Just a comment for this thread...5W-40 Synthetic will make a big improvement in cranking and starting compared to 15W-40...provided all things are in proper working order. Even 10W-30 will make some improvement...but I know from experience that 5W-40 is a huge difference when temps are in the single digits.
5W-40 Rotella T6 and it is 11 degrees here this morning. The heater is plugged in...truck spins up quickly and no strain on the battery or starter or anything else...except maybe the wallet 'cause of the power bill. The truck will warm up quickly and the frost on the windshield will not last. Someday I may look at the power bill and get the cost per Kwh and know for sure what it cost...don't really care...just curious.
I figured it up last year. It came out something like it was twice as expensive to not plug it in by the time I would start it and high idle it for 5ish minutes vs plug it in for 2hrs and take off slow. I might have lower electricity rates than some of you though.
I rarely plug my truck in and I'm from Norther Nebraska. I will plug in if lows are below 0 but thats about it and mainly so the cab warms up faster. I have on several occasions sarted my truck, after sitting out all night, at -15 and lower. That happens when I am in Colorado on snowmobile trips and have no place to plug in. I also did the same with my 7.3 but my 6.0 does a better job of starting. Its amazing how well our 6.0's start when cold.
These motors make a nasty noise when fired up at -30c without a block heater.Then there is the cloud of unburnt fuel that envelopes the truck that the neighbours don't seem to like much.
