how cold before plugging in block heater
Old Dec 9, 2011 | 11:42 AM
  #31
zhilton's Avatar
zhilton
Originally Posted by IHbase
10 degrees. Anything above is a waste of money.
So is driving a 3/4 or 1-ton truck when it's just you in the cab...nothing in the bed and nothing on the hitch. But just like the oil you use, or tires you ride on...it's a matter of choice.
Originally Posted by XB70
How many of you block heater heads have 15W-40 in your sumps?
Currently I'm running a syntheic blend 15W40...should be making my winter change to 5W40 here in a couple of weeks when the truck comes due. I've run the 15W40 to -13F and the truck started. It wasn't happy and I'm sure it wasn't good for it (forgot to plug it in the night before). I still say, if you want to run the block heater...go ahead; if not...it's your truck & your money. Like everything else on here, half of these things are personal preference.
Old Dec 9, 2011 | 12:17 PM
  #32
XB70's Avatar
XB70
Originally Posted by brickie
These motors make a nasty noise when fired up at -30c without a block heater.Then there is the cloud of unburnt fuel that envelopes the truck that the neighbours don't seem to like much.
Not mine. I've cold soaked at -25F (-32C) for eight to ten hours and started without a block heater several times. On one occasion, another 6.0 was parked next to mine and we both started up at the same time.
My truck didn't make a nasty noise,nor did it belch unburned fuel out the exhaust. It took about 3 seconds to fire instead the normal 1 1/2. It idled a little rougher for about 30 seconds and I drove off slowly after 3 -4 minutes.
The other truck behaved like yours - a long grinding start followed by an idle that shook the entire truck. The owner got out of his cab and asked how I got my tyruck to start and run so easily.
5w-40 synthetic and a Deltran Battery Tender that's hooked up whenever my truck is at home - even for 10 minutes.
He had 15w-40 conventional and three year old batteries and didn't know how to check electrolyte levels or what a Battery Tender is.
I'll take 5w synthetic and 100% batteries over a block heater any day. As for you guys that think +29F is cold, get real. Better yet, get some 5w-40 and maintain your batteries. Or, save a few bucks on oil and carry on - I love reading these threads.
wuttrd
Dec 29, 2009 04:43 PM
motoman620
Dec 6, 2006 08:06 AM
rockford04
Oct 26, 2005 05:47 PM
tsheriff
Jan 19, 2005 12:47 AM
tofer76
1997 - 2003 F150
Dec 14, 2004 07:22 PM
