How long are you guys idling at freezing temps before driving?
I'll idle for 5 to 30 minutes, depending on the temps. With the manual high idle you'll help eliminate wet stacking which is the problem with normal idling.
When we hit -7 below F or colder I set my rig to auto run for 36 minutes every 2.5 hours to keep it thawed and make sure it'll start after 10 hours of sitting out in the cold on some isolate pull out with no power to plug into
Experience can be a hard lesson when your rig freezes up and it's -25 below F and your a 100 miles from anything.
LA_BigRed
28
12-03-2004 11:59 AM
