Choke Cap Setting
Old Dec 8, 2011 | 12:58 PM
LARIAT 85's Avatar
LARIAT 85
Choke Cap Setting
For those of you that are still running a choke cap with electric-assist, where is your choke cap indexed? As in 2 rich, 1 rich, center mark, 1 lean, 2 lean...etc.
Thanks!
Old Dec 8, 2011 | 02:43 PM
devino246's Avatar
devino246
Got mine set at index, as per the emissions label under the hood.
Old Dec 8, 2011 | 05:53 PM
LARIAT 85's Avatar
LARIAT 85
Thanks, Devino. Are still running the stock Motorcraft choke with the hot air choke tubes? Do you have a different setting for the summer weather and another for the winter season?
Old Dec 8, 2011 | 05:59 PM
devino246's Avatar
devino246
Yep, stock hot air tube. No change for seasons.
Old Dec 8, 2011 | 07:24 PM
Action4478's Avatar
Action4478
With the Accelerator pedal wide open , or off idle , Set the butterfly closed ( if the motor is stone cold) .. WHen the motor starts , the choke pull down should open the butterfly a little . When the choke coil begins to heat up , it opens the choke gradually as it warms up
JC86F150
Mar 30, 2017 03:19 PM
ericford1984
16
Apr 1, 2014 07:35 PM
1981Ranger
Oct 8, 2013 07:46 AM
Rick_Fury
Jan 27, 2010 02:13 PM
84-250
Mar 2, 2003 11:19 AM
