altinator interchangeability
Old Dec 7, 2011 | 06:54 PM
the almighty schmuck's Avatar
does anyone now if the alt. for a 7.3 is the same as a 6.0. i ask because i might be able to get one for free thats only 2 weeks old. the way it was described to be it sounds like the same alt. just clocked different.
i jumped a international today at work then when i tried to leave it almost didnt start then took the whole 20 min. drive home to get back to its pathetic 13.5 volt reading and thats with the lights and heater off
Old Dec 7, 2011 | 07:41 PM
BLADE35's Avatar
BLADE35
To me I wouldnt try and use a diffrent alternator for a diffrent model the Electronics are very expensive in the 6.0
But that said looks like there the same amperage 110 amp for your bAsic setup 6.0 & 7.3 and the connections to the wire harness looked the same but the connections have diffrent orintation ]location] and the mounts maybe a touch diffrent but the wiring does have diffrent location
and then some models have 2 alternators so a Lower unit maybe way diff depending
It didnt look close enough for me to try something like that
This is what I use and have had no problems with its a DC Power 190amp altternator they are a little spendy but I havent heard of any issues on FTE and there is a Few folks running them Oh I did get the optional wire upgrade to but I got it free so if you wanted to save $$$ you could have napa make you one for like 20.00 High Binder had one made you could ask him the details about it
https://www.dcpowerinc.com/vaf/produ...70&engine=1015
If you get a DC Power one you wont have to worrey about it
I also think its the case where you want the exact part for your ride
Old Dec 7, 2011 | 10:42 PM
thanks, i answered my own question i went to look at the one my buddy had and its wired different
Old Dec 7, 2011 | 11:15 PM
are the altinators you get from autopart stores just as crappy as the factory ones? i wouldnt want to spend the money and still only get 13-13.5 volts
Old Dec 8, 2011 | 03:11 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
I bought a 250 amp alternator off eBay for 190$. Direct bolt on an works great. Only needed one that big b/c of the sound system im puttin in my truck. Had the alternator bout 4 or 5 months an no problems so far. My scangauge shows 13.5 to 13.9 all the time.
Old Dec 8, 2011 | 08:41 AM
DSMMH's Avatar
DSMMH
I would suggest you run a 2nd load wire from the alt. to the passenger side battery. The OEM wire is only sized for the OEM 110 amp alt and not the AM 190 amp alt.
DSMMH
redbull660
16
Jan 30, 2022 12:20 PM
MiamiPSD
Aug 29, 2014 11:21 PM
pin8246
Jun 4, 2014 09:21 AM
daddykitty
Dec 28, 2012 03:59 PM
02GrayPowerStroke
Jul 11, 2010 07:27 PM
