Different no start problem
Old Dec 6, 2011 | 12:48 AM
RedDragon's Avatar
RedDragon
Sorry if this is a repeat, but i couldn't find a similar issue searching. I have new batteries and full charge, but when I turn the key there is complete silence...crickets. There is no buzzing/clicking from solenoid and no spin of the starter. I replaced the starter solenoid on the passenger fender and no change. I'm stuck in Tucson about 30 miles from home. Any suggestions on what to try? Thanks
Old Dec 6, 2011 | 02:00 AM
carltonwebb's Avatar
carltonwebb
If its an automatic, try putting the truck in neutral and starting. Or wiggling the shifter. If that does it, the torx bolts may be loose not letting it full engage park.
If all else fails, use a screwdriver and connect the two large wires on the the starter solenoid that you replace. If that does not crank it, hit the starter with a rock/hammer and also make sure all the wires are tight and the starter is tight to the engine. There have been cases of the starter loosening up.
Old Dec 6, 2011 | 10:43 AM
RedDragon's Avatar
RedDragon
No Luck yet..... anything else to try?
Old Dec 6, 2011 | 10:47 AM
clux's Avatar
clux
Have you checked for blown fuses?
Old Dec 6, 2011 | 10:56 AM
RedDragon's Avatar
RedDragon
Yes, no blown fuses.
Old Dec 6, 2011 | 11:05 AM
cougarman001's Avatar
cougarman001
This may sound pretty basic but do the headlights come on? If yes do they stay on when you try to crank the engine? If you can't see the headlights while trying to start do the lights stay on in the cab?
Old Dec 6, 2011 | 11:10 AM
clux's Avatar
clux
Do you have a chip installed?
Old Dec 6, 2011 | 12:17 PM
RedDragon's Avatar
RedDragon
Headlights come on, but go out when key is in start position; interior lights stay on. DP-F5 chip installed.
....It cranked once and almost started. On the next try a minute later, it's back to nothing... silence while turning key to start position.
Old Dec 6, 2011 | 12:31 PM
BillyBob69's Avatar
BillyBob69
This almost sounds like a bad connection at the batteries or bad ground.
I would start at the batteries and work your way from there. Make sure all connections are clean and tight.
Also check the wiring at the starter.
Old Dec 6, 2011 | 02:54 PM
cougarman001
It sounds like the battery may be dead. Did you try jumping it? The other possibility is just a dirty battery cable. If you can't pull the battery cables to clean them I've had success twisting a screwdriver or even the ignition key between the battery post and the cable. This may make a connection between the post and the cable just to get it going.
Old Dec 6, 2011 | 02:58 PM
duck fan's Avatar
duck fan
Because racetruck
Have you tried starting in neutral?
Old Dec 6, 2011 | 09:49 PM
cougarman001
Did you get this beast going? Just curious if you found the problem.
Old Dec 6, 2011 | 10:00 PM
RedDragon's Avatar
RedDragon
Haven't tried it in neutral yet (it's automatic).... had to leave it and go to work. I'll try that tomorrow. Thanks for the help.
Old Dec 7, 2011 | 08:52 AM
cougarman001
I don't believe putting it in neutral will make a difference. The headlights wouldn't go out in the start position if that was the problem. I still agree with BillyBob69 that it's a connection problem or just a dead battery. You mentioned you have a new battery. What do you mean by new? Did you change the battery before this happened? Did the truck just die while it was running or did it just fail to start after it was shut off? It's possible your charging system is failing or another possibility is a bad starter. Let us know what you find.
Erv
Old Dec 7, 2011 | 10:08 AM
BillyBob69's Avatar
BillyBob69
Wait..."A new battery?" Not both? Not a good idea. SHould replace both. An old one will bring down and mess with a new one.
