Cooling problem
Old Apr 14, 2003 | 11:19 PM
mrtn1245's Avatar
mrtn1245
Cooling problem
Alright here is my problem. My radiator fluid keeps disappearing. I am not seeing anything left on the driveway or parking spots. And my engine is getting hot quicker. It hasn't yet reached 260 but i bet it gets up to about 210 or so. That is even when i am breaking my own wind and not drafting no one. I do a decent amount of highway driving. I have a 94 ford ranger 4.0L 5 spd manual. Any help at all is appreciated. Do you think it is the head gasket? If so hard is that to change on a 4.0L? Could it be a waterpump or even a thermostat or something stupid?
Thanks
Matt
Old Apr 15, 2003 | 11:58 AM
MustangGT221's Avatar
MustangGT221
Cooling problem
If it was a head gasket, you'd be seeing white smoke out of the exhaust. How much coolant disappears in how long?
Old Apr 15, 2003 | 12:51 PM
mrtn1245's Avatar
mrtn1245
Cooling problem
i would say maybe about a quart or so every 2 weeks.
Old Apr 15, 2003 | 01:30 PM
luke_trash's Avatar
luke_trash
Cooling problem
it's going into the engine if it's not leaking from anywhere.
check your oil for contamination.
it's best to fix this sort of situation asap, so it doesn't lead to a non-running condition.
My friend just put a new engine in his chevy truck, due to a simple intake manifold gasket leak.
Old Apr 15, 2003 | 01:41 PM
mrtn1245's Avatar
mrtn1245
Cooling problem
oil is looking good also. It is a little dirty because i need to change it but it looks just normal.
Old Apr 15, 2003 | 05:22 PM
EPNCSU2006's Avatar
EPNCSU2006
Cooling problem
Tighten hose connections if you can. It could be leaking out somewhere and evaporating before it hits the ground, so you won't see it.
Old Apr 15, 2003 | 06:05 PM
mrtn1245's Avatar
mrtn1245
Cooling problem
thankyou. I do see some stains on the block around the upper radiator hose like where the thermostat is. I am going to look at it tomorrow. Any other advice would be greatly appreciated
brain3278
1983 - 2012 Ranger & B-Series
15
Jul 3, 2009 10:22 AM
aphotic26
Dec 3, 2008 05:18 PM
turboman24
Aug 13, 2007 12:28 AM
maa139
Jun 13, 2003 06:54 AM
mwittman
Mar 9, 2001 02:12 PM
