Window comes off the mounting sections
Old Dec 5, 2011 | 05:37 PM
hodges710's Avatar
hodges710
On my 98 expedition I went to roll the pass. rear window down and it went down about 3 inches and that was it. I heard a sound when it stopped so not wanting to break anything, I took the door skin off and could see the window was not connected to the piece ( not sure what it is called). What is the best way to connect them back and is there anything i can do to prevent another seperation.
Old Dec 5, 2011 | 07:13 PM
waldosnavi's Avatar
waldosnavi
Same thing happend to me on my 98 navi, I cleaned the bottom rail where the window rest's with a wire brush and glued the window to the rail it rests on. I think thats the way window installers do it. Havnt had a problem with it in 2 years or so.
Old Dec 6, 2011 | 06:07 AM
Gevans17's Avatar
Gevans17
window glass to regulator
rear window glass mounts to regulator via 2 bolts/nuts
Old Dec 6, 2011 | 06:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Door glass is adhered to their channels with 'glass tape' .. available at any autoglass shop.
Old Dec 6, 2011 | 06:25 AM
Gevans17's Avatar
Gevans17
Question window-regulator mounting
My Ford reapir CD shows 2 bolts/ nuts for the 98 Expy. Is the glass taped into the regulator on the newer Expys?
Old Dec 6, 2011 | 07:24 AM
2Fords1Jeep's Avatar
2Fords1Jeep
I used silicone caulk on mine. Leave the window in the up position for 24 hours before using to allow it to dry.
Old Dec 6, 2011 | 07:48 AM
alwaysfords41's Avatar
alwaysfords41
You might want to check the child locks while you are in there....
Old Dec 6, 2011 | 12:29 PM
hodges710's Avatar
hodges710
Thanks for allwho responded, I got the window fixed and should not have another issue. As for my childs locks, lol I am not the one that was having problems with them, mine work just fine.
DanS12
Jul 23, 2016 03:06 PM
petercrabbe
Jan 11, 2014 08:14 PM
eaglestone
Jun 20, 2010 10:03 PM
great white
Nov 9, 2004 11:40 AM
biederboat
Aerostar
May 26, 2003 09:02 PM
