Hey guys Need some help I've got a 81 f100 straight 6 I think it's a 300 but. I'm going to have to replace my lower ignition switch an was wondering if anyone knew how to do it an had any pics an if anyone knew what kind of job it's gonna be.
Remove the headlight **** + stalk, there is a mechanical button on the switch assembly itself, you need to reach your hand up into there and push it while you pull the **** off:
Similar to this:
Remove the dash gauge cluster trim, the piece of plastic trim beneath the steering column, you'll see a piece of aluminum bracket held onto the column with I believe 4 bolts or nuts (10MM I believe) and there are I believe two (might be 4) bolts holding that aluminum piece + column to the dash assembly; remove those two and the column should drop into your lap, making the switch easily accessible (the switch might also be 10MM but I don't remember for certain).
Wow thanks. Quick question I believe that this may be the problem it's possibly stick but only every now an the when I go to crank it it drags like it is a dead battery
The starter and solenoid. I've read so many times on this forum that the solenoids you get now are cheap POS. Try a different solenoid. That may fix your issue.
