84 Ignition Switch Removal
Old May 3, 2006 | 10:09 PM
MustangMann's Avatar
MustangMann
Question 84 Ignition Switch Removal
Hello,
does anyone know how to remove the ignition switch?? My chiltons says remove the column shround and im not sure what that is.....used to older vehicles
please let me know
Old May 3, 2006 | 11:44 PM
Chiefrider007's Avatar
Chiefrider007
The shroud is the cover over the steering column, just below/behind the steering wheel. One screw in the bottom but, first you should remove the small piece of dash that covers the shroud. One screw on either side, bottom of dash with the column running through it, then the shroud will come right off. Be watchful of your shift indicator cable if you have auto trans.
Christopher Layton
Sep 22, 2015 07:45 AM
Leith
Aug 3, 2010 09:03 PM
tompmatthews
Dec 2, 2009 11:46 AM
samahi72
Apr 23, 2008 12:59 PM
Wendy67
Dec 15, 2004 10:58 PM
