Transmission Mount?
Old Dec 5, 2011 | 12:40 PM
1949 F6's Avatar
1949 F6
Transmission Mount?
I might be buying a 89 F350 Diesel as a donor truck to my F6. I will be using the motor, crossmember, mounts, ect. The only problem is it has the auto tranny in it and I will be using a zf5 in my project. So my question is the tranny crossmember/mount the same for the auto tranny as the zf5? Thanks for the help
Old Dec 5, 2011 | 01:06 PM
cj06's Avatar
cj06
the mounts seem to be the same , and the crossmember should work but if you are putting the combo in that old 49 thats in your pictures then you will have to do some fabrication on that crossmember or make a custom one from scratch !
will be a good project and be sweet when done so good luck !
Old Dec 5, 2011 | 04:23 PM
1949 F6's Avatar
1949 F6
Awesome I was hoping that would be the case. Yeah I'll have to to some... extensive modifications. Thanks for the help!
custom cabby
Jan 20, 2008 08:31 PM
greenacres
Oct 21, 2007 02:39 PM
maschronic
May 6, 2007 11:59 AM
1978fordf250
Jun 19, 2004 04:16 AM
