Sponsored by: Real Truck
Need some help with installing tailgate lightbar
Old Dec 4, 2011 | 05:57 PM
btacarlton's Avatar
btacarlton
So I bought a tailgate light bar off of ebay. It has the scanning turn signal feature. After reading the install instructions, I realized I need to install the turn signal wires to the front turn signal wires because the rear turnsignals and brake are the same wire. I called the company and verified this with them. I also need to connect to a key on 12v source. My question is, what color and where are the front signal wires located under the dash? I figure while I connect to a 12v source I can just connect the signal wires at the same time. Any help is greatly appreciated.
Bill
Old Dec 4, 2011 | 07:00 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
use your 7 pin or 4 pin trailer harness for those wires
go to Walmart or most any parts store and purchase a 4 pin trailer connector.
wire that connector to your bar and then simply plug it into your 4 pin
Old Dec 4, 2011 | 07:03 PM
btacarlton's Avatar
btacarlton
per the install instructions it says not to use the 4-pin connector. the company says I need to wire to Front turn signals not the rear.
Old Dec 4, 2011 | 07:54 PM
btacarlton's Avatar
btacarlton
Anyone......?
Old Dec 4, 2011 | 08:47 PM
rray32539's Avatar
rray32539
Sounds like the logic circuit they are using relies on a separate turn signal and brake light. Not all light bars are like that. Mine uses the tail light circuit for use in lighting at night and the rear turn signal circuits for the turn/brake function. If you want to run wires along the frame and tap onto the front turn signals, be my guest. I would return the light bar myself and not deal with the drama that light bar puts you through.
Old Dec 4, 2011 | 09:33 PM
btacarlton's Avatar
btacarlton
Well as far as returning, Im past the point of no return. Would like to wire turn signals under dash, buy can't seem find wires with intermittent voltage when signals are on.
Old Dec 4, 2011 | 10:25 PM
btacarlton's Avatar
btacarlton
Do I need to wire in after the Smart Junction Box since this controls the turn signals?
Old Dec 4, 2011 | 11:08 PM
SoFla David's Avatar
SoFla David
I just tapped into the front turn signal wires to install my lighted mirrors using this link:
TheDieselStop.Com - www.thedieselstop.com
you would be tapping into the same wires.
Old Dec 5, 2011 | 03:12 PM
btacarlton's Avatar
btacarlton
Thanks for the info.
jimjokjv
Aug 8, 2018 11:01 PM
JayzDaddy
May 31, 2013 02:52 PM
SideWinder4.9l
Apr 27, 2011 04:35 PM
phillips91
May 29, 2010 01:19 PM
