Turn Signal Issue
Old Aug 8, 2018 | 09:11 AM
jimjokjv's Avatar
jimjokjv
Turn Signal Issue
My right front turn signal quit working the other day. Parking light and side marker light worked but no turn signal. After swapping out bulbs and having no success, I traced the lead all the way back to the firewall junction block and it checked out as good using a volt ohm meter.
Finally pulled the cover off the steering column and this is where I found the problem. The connector that plugs into the turn signal switch is not holding the pin connectors in place. The wires with their pin connector ends are easily pulled out and do not "click" into place on one side of the connector.
Not being well versed in how the pin connectors are secured into the plastic plug I am not sure if I need new ends on the wires or a new plastic plug?
Old Aug 8, 2018 | 09:34 AM
timmyboy76's Avatar
timmyboy76
Having pulled a few pins out to tap into them, remove the spade and you'll see either 1 or 2 "fangs" that ned to be soread out so when inserted into the plastic plug, they"ll then rebound out over the "lip" within the plughole to finally secure the spade in place
Old Aug 8, 2018 | 08:52 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Maybe a small zip tie will hold it together?
Old Aug 8, 2018 | 11:01 PM
jimjokjv's Avatar
jimjokjv
I didn't notice any "fangs" on the pins. Maybe they were there but very small and flattened.
Great minds think alike, I did use a zip tie to secure it this time. Just want to be prepared for a proper repair should my rigging not hold.
littleredford69
1978 - 1996 Big Bronco
Feb 20, 2016 01:38 AM
CDavis26
Jun 22, 2015 12:15 PM
josh.crotsley
Dec 27, 2014 08:19 AM
pressureelite
1997 - 2003 F150
Apr 25, 2010 04:18 PM
