4x4 issues
Old Dec 6, 2011 | 09:35 AM
jasonodsky's Avatar
jasonodsky
Hey Fordman96, just an FYI the hub locks you have are "Warn" brand, not "Warren"
I'm gettin' ready to watch Mustangz_04 casplode
Old Dec 6, 2011 | 03:27 PM
azex2001's Avatar
azex2001
LOL!!! thanks Mustangz_04, I had a good chuckle.
Old Dec 6, 2011 | 03:39 PM
EXv10's Avatar
EXv10
Originally Posted by njneer1
Which needle bearings do you reference?......I was thinking the needles the stub axle shaft rides on.....
Yes, those.
Old Dec 6, 2011 | 07:22 PM
Fordman96's Avatar
Fordman96
My bad guys... I wasn't quite focused on what I was saying as long as I could try to get my point across
I've been trying to see what happens driving around with the hubs locked in. I unlocked them today. The noise doesn't happen AS OFTEN but it happens 99% of the time I make a sharp turn. Like into a parking spot.
Old Dec 7, 2011 | 07:59 AM
jasonodsky's Avatar
jasonodsky
OK now that is sounding more like tight or bad u-joints. (low speed tight turns) But you may have both bad needle bearings and u-joints. Needle bearings will present while driving straight at higher speeds.
Old Dec 7, 2011 | 01:30 PM
EXv10's Avatar
EXv10
What he said....above
Old Dec 7, 2011 | 07:02 PM
Skinsfan6's Avatar
Skinsfan6
Jack up one of the front wheels with both front hubs unlocked, transfer case in 2wd. Spin the tire. If there is a light but frequent clicking, your needle bearings are bad. Mine made this noise for a year or so. The needle bearings get play in them and are really grinding but with little weight on them, so it is not a very harsh sound. It sounds like a tin can rolling around with rocks in it. I did not choose to replace the needle bearings in the auto hubs because I don't like the ESOF system, so I bought Mile Marker 449-SS manual hubs that obviously have their own bearings in them. This fixed my noise. And remember, if this sound is present, the needle bearings are bad. But I did not say if the sound is not present, the needle bearings are fine.
Old Dec 7, 2011 | 11:15 PM
EXv10's Avatar
EXv10
It is typical for needle bearings (on the stub shaft) to make noise right when you hit a bump in 2WD.
dakeddie
Feb 20, 2019 07:50 AM
andybear5014
Dec 4, 2013 06:58 PM
flip1950
Dec 26, 2010 08:03 AM
Mopey
Jun 23, 2005 08:00 PM
Ford35003
Mar 31, 2004 11:42 PM
