Tips on getting stand pipes out??? 2005
Old 12-03-2011, 07:00 PM
FSeybert's Avatar
FSeybert
FSeybert is offline
Hello,
I have my 2005 F-250 torn down due to a loss of HPO pressure. I have the upper section of the stand pipes out, but the lower section is being quite the pain. Any tips?
Thanks.
Old 12-03-2011, 07:05 PM
Shaneb75's Avatar
Shaneb75
Shaneb75 is offline
Strokin Okie
I had the same problem on the drivers side. I just replaced the top piece and got on down the road. I have heard that you can remove the hpo rail to remove the lower section, but not 100% sure...
Old 12-03-2011, 07:39 PM
FSeybert's Avatar
FSeybert
FSeybert is offline
Yeah, I have the oil W pipe out. The stand pipe is being quite the pain. I can turn it, wiggle it, move it around in the hole but it wont budge. I had the 19 year old weight lifter next door try to pull it out, no go.
Old 12-05-2011, 10:28 AM
jimmyv13's Avatar
jimmyv13
jimmyv13 is offline
I used needle nosed pliers from SK after a few attempts with other tools. I marred it up pretty good working it with different tools so I HAD to get it out.
Tell your neighbor he's a pansy once you get it out!
Old 12-05-2011, 01:18 PM
FSeybert's Avatar
FSeybert
FSeybert is offline
I got it. Had to make a puller, but I got them both out. The 35 degree ambient temperature wasn't helping matters! The o-rings were hard as a rock.
RDavis - OKlahoma
2004 - 2008 F150
08-12-2005 07:59 PM
old87
Georgia Chapter
116
06-09-2005 09:30 AM
Firedenfels
02-14-2005 10:13 PM
mountainman
2004 - 2008 F150
07-19-2004 09:34 PM
Quick Reply: Tips on getting stand pipes out??? 2005
