failed smog!
Old Dec 4, 2011 | 10:35 PM
85e150's Avatar
85e150
Old Dec 5, 2011 | 10:47 PM
dirtydeeds's Avatar
dirtydeeds
post up your printout.
my neighbor uses 20% methanol just before the test. cleans things up nicely.
as already stated, a good tune up, as much timing as possible and still be within range, idle screws lean as possible and still have good manners, accelerator pump lean as possible and still have manners,
tune to lean until manners go away then add fuel back to find limit. too lean and popping will cause NOX, too rich making good power will cause high Hydrocarbons.
Methanol or E85 will clean up a lot of that, tune with whatever mixture you intend to use, don't use too much, there is less BTU and you'll have to up jets, max is 15-20% then tune as stated above.
Old Dec 6, 2011 | 04:19 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by jgavac
Oh really? That's interesting. Any idea why?
I don't have to worry about smog testing.. No emissions controls in my county
Something about people can take the catalyst in the converter and being able to make bombs out of them. Same reason why you cannot buy a converter from a wrecking yard.
Even buying one from the parts store takes a hell of a lot of red tape here in CA.
Old Dec 6, 2011 | 04:21 AM
81-F-150-Explorer
This includes changing your oil and filter. Preferably clean oil with less than 200 miles on it. Your truck can fail a smog test if your oil needs changed.
Old Dec 6, 2011 | 04:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Do away with smog tests for older vehicles. Get rid of the tree huggers, liberal do-gooders, ridiculous and confusing BATF & DOJ gun laws and...a gazillion illegals, CA would be a wonderful state to live in...like it once was.
Old Dec 6, 2011 | 05:23 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Nothing really to add... Just wanted to read that twice! 2X I agree wholeheartedly!!!
Dace
Aug 9, 2015 12:00 PM
calmaggi
17
Feb 24, 2015 10:05 PM
Catherine M Fisher
15
Jun 16, 2013 06:23 PM
dragonisfury
Dec 16, 2012 04:38 PM
matrdefndr
41
Dec 25, 2008 09:02 AM
