1 Ton springs
1 Ton springs
I have a 75 ford 1 ton dump truck (I affectionately refer to it as the humpty dumpster.)
It is two wheel drive and the front has begun to sag. Not really bad, but since I load the hell out of it hundreds of times a summer, I should most likley take care of it.
I was just wondering the best place to purchase new front coils?
Thanks for the help.
1 Ton springs
Did it raise the front up. When I bought the truck it was sagging a litlle, gotten worse over the last year. But I never saw the truck when the springs were good, so i dont know how high the front should be, I am hoping It will bring it up a couple inches, it should, I think they are the original springs.
Thanks alot
Thanks alot
1 Ton springs
Actually, the drivers side springs was broken at the top on my '78. They were the factory orignals and I replaced with the same weight rated springs. But I measured it anyway. I gained an inch from the new springs. If you really want to beef up your truck, tell the auto parts you want the springs for the 10,000 gvw truck. I think they were on F350 super camper specials.
Lenny
Lenny
