Sponsored by: Auxito
Door ajar?!?!??
Old Apr 14, 2003 | 07:55 PM
Eazy's Avatar
Eazy
Door ajar?!?!??
Hey,
Just have a quick question. I have a 98 f150 stx. 4.6, 5 speed, long bed, etc... Sometimes when I close the door, The door ajar light stays on, which in turn leaves the dome and cargo lights on. Not really a big deal, but when I set the anti theft, the alarm will go off in the middle of the night, or it will be going off when I come out of the home depot, or something along those lines. I was just wondering if anybody else has had this problem?
and if so, how was it fixed????
Any info would be great, thanks guys.
Old Apr 14, 2003 | 11:33 PM
Racerguy's Avatar
Racerguy
Door ajar?!?!??
If you do a search here you'll probably find lots of posts about this problem. Basically the switches in the door lateches stick and you have clean them out with WD40 by spraying a whole bunch into the latch. Just open the door and aim the WD40 into the latch and start spraying. After you've sprayed lots in there open and close the door a few times and then spray some more. After a couple times your lights will work ok again.
Use WD40 as it cleans the junk out of the latch and switch and doesnt attract dirt like grease would.
Old Apr 15, 2003 | 09:45 AM
Eazy's Avatar
Eazy
Door ajar?!?!??
Thanks, I will give it a try and let you know how it works out.
Old Apr 15, 2003 | 05:00 PM
sudds's Avatar
sudds
Door ajar?!?!??
Thanks loads for your help. I tried the WD-40 and it worked great. You have saved me about $40.00 for a service call.
John
Old Apr 15, 2003 | 07:03 PM
Racerguy's Avatar
Racerguy
Door ajar?!?!??
You're welcome
Old Apr 16, 2003 | 08:32 AM
WXboy's Avatar
WXboy
Door ajar?!?!??
Yeah...that will work great for a while. It'll come back though. I finally just took my door panels off and cut the wires to the switches. NO more door ajar....ever. (I don't have an alarm system on my truck however).
Old Apr 16, 2003 | 09:44 AM
Eazy's Avatar
Eazy
Door ajar?!?!??
Ya, it worked great, Thanks, I will keep you updated, just in case it comes back.
Old Apr 18, 2003 | 12:30 AM
calvino's Avatar
calvino
Door ajar?!?!??
i have the same problem on my 97 f-150 longbed, when it is cold then the door ajar turns off and then when it is warm it will turn off after 2 min. when it is hot out then it won't shut off at all. it is really annoying, and I don't know how to fix it. can you help???
Old Apr 18, 2003 | 12:57 AM
Racerguy's Avatar
Racerguy
Door ajar?!?!??
Have you tried the WD40 trick?
sbappleg8
1983 - 2012 Ranger & B-Series
15
Aug 2, 2017 11:45 AM
Chargerkid
Jul 21, 2017 07:14 AM
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
sednec
Feb 7, 2008 09:58 AM
bager
1997 - 2003 F150
Mar 17, 2004 06:55 PM
