Today's work - I changed fuse
#22. It was burned out because of the fuel bowl heater probably being shorted out. Then I replaced the CPS. that was a real bear. I ended up taking off the serpentine to make work much easier. After That was done, I put everything back together. Here are the results. First the WTS light did not come on at all. The truck cranked over but did not start. I need to try again because I did watch for the tach to see if it registered. What's next?
When you changed the fuse #22 did you unplug the fuel heather connector?
I got it going tonight. One of the neighbors came over to help me. He has worked on the PSD quite a bit. He showed me that I had not unplugged the wire to the fuel bowl heater but unplugged another wire close to it. I made a jumper and placed in slot #22 and the truck fired right up. He said that the Fram filter was a little longer than the Motorcraft and put pressure on the bottom of the filter housing which caused a problem with the bowl heater. I do not know if that is true or not but the truck is running. By the way I do not have a chip in the truck.
Good deal. I have not heard that about the Fram filter, but it wouldn't surprise me. Glad you got it running! Don't be a stranger around here just because your truck is running again.
I won't be a stranger to the site. This is my first diesel truck. I have had 5 other ford trucks including another F250. All of them were gas powered. I use this truck to haul logs out of the woods at the farm. The FWD really helps going through the soft ground.
Do you know where I can get a chip that will get me better fuel economy? Is this something the average wrench turner can do? Are the chips reasonable to pay for themselves?
After I got the truck running I decided to do some more checking. I used my multimeter with the continuity tester on the engine block heater plug. It did not beep so I think that the heater is not working. Last year I taped the wires since the plug and wires were coming apart. What is the chance that the wires are bad and not the block heater? Is there a fuse to check for this, if so what is the number?
The block heater isn't part of the truck's electrical system, so there's no fuse. If you put the continuity tester between the hot and neutral blades on the plug, it wouldn't beep, because the heater is a big resistor. Resistance should be about 15 ohms. If it's open (infinite resistance), try removing the plug at the heater end and check the resistance right at the heater. If that's okay, it means the heater should be good, and I'd be looking for a new feed cord. They're semi-generic; you can get 'em at NAPA.
I want to have everything working before the really cold weather hits. Here in PA it does go well below 0. Last year we had almost a month of below freezing temps. I don't want to be working outside on a cold truck in weather like that. The winter before my truck was the only vehicle to be able to get into our road due to the snow.
