What else should I do while installing head studs?
Old Nov 30, 2011 | 02:15 PM
LRSTony's Avatar
LRSTony
okay looks like i have a leaking head gasket so it's head stud time. i've been doing some searching but i want to cover all my bases and get everything done at one time and i don't want to forget anything. so my question is what should i be replacing while the engine is out of the truck? it's an 05' with 90,000 miles on it, already has the egr delete. here's what i have in mind but if there are other things i should do please let me know.
arp head studs
new oil cooler kit
possibly new injectors
clean the turbo?
Old Nov 30, 2011 | 02:26 PM
cartmanea's Avatar
cartmanea
Do a thorough coolant flush with Restore and Restore Plus before tearing it down. That'll clean and prep the system for the new oil cooler. I would also switch to an ELC coolant afterwards. Don't worry about new injectors if you don't have any cold start or other issues, but you will need new o-rings for them. Cleaning the turbo won't hurt while it's apart. I would also update the STC fitting on your HPOP if it hasn't been done yet, and also do the stand pipes and dummy plugs on the oil rails.
Old Nov 30, 2011 | 02:31 PM
LRSTony's Avatar
LRSTony
thanks! guess i should have stated i did the coolant flush with restore and vc-9 and replaced with an ELC.
Old Nov 30, 2011 | 02:39 PM
cartmanea's Avatar
cartmanea
Good! Also thoroughly check your block deck and heads for flatness, and be careful cleaning them to avoid damaging the surfaces.
Old Nov 30, 2011 | 06:30 PM
Mich6.0's Avatar
Mich6.0
new oil cooler? egr cooler? don't know if you have a coolant issue
Old Nov 30, 2011 | 06:33 PM
cartmanea's Avatar
cartmanea
If you read his original post... He is already doing an oil cooler and has an EGR delete. From follow up posts, sounds like his coolant system is in order.
2006powerstroke90
Nov 27, 2016 06:46 PM
tesmith66
Jun 18, 2012 01:24 PM
AGE mechanic
Aug 10, 2011 08:48 AM
white04kr
Jun 25, 2011 12:47 PM
caere
Aug 13, 2010 03:34 PM
