Headunit
Old Nov 29, 2011 | 05:49 PM
Nickdbethebest's Avatar
Nickdbethebest
Headunit
I have a 2004 ford f150 xlt crew cab and have a facory system. I want to put a new touch screen headunit in. recomandations ?
Old Nov 29, 2011 | 06:40 PM
MCDavis's Avatar
MCDavis
Welcome to FTE!
Pioneer, Kenwood or Alpine are the makers I would look for and then whatever model fits your budget.
Crutchfield: Car Stereo, Speakers, Home Theater, LCD TV, Digital Cameras is a good place to start...lots to find there.
Old Nov 30, 2011 | 12:50 PM
Nickdbethebest
im looking at a touchscreen kenwood.. Is it and easy installation or should i go get it professionally done
Old Nov 30, 2011 | 12:58 PM
MCDavis's Avatar
MCDavis
Depends on how confident you are. Some are plug and play, others will require a splice or two.
Crutchfield will sell you all that you need if you go through them. Pro shops (installers) usually back their work for as long as you own the vehicle. I like that peace of mind and have my electronics installed by the shop. Cost isn't much more honestly.
Old Nov 30, 2011 | 01:04 PM
CMOS's Avatar
CMOS
Nick,
A while back I installed a head unit with a kit that I bought at Crutchfield. I had no problems as the support and instructions from them were excellent.
If you're patient and a tinkerer, I'd say do it yourself.
I also soldered ALL the connections to the pigtail connector that Crutchfield sold me whereas a shop would just put on those cheesy crimp connectors. The solder helps reduce/remove the amplifier hiss.
CMOS
Old Nov 30, 2011 | 05:45 PM
Nickdbethebest
thankyou one more question i have the factory subwoofer ford gives you the option to have when i bout my truck i want to add another can i do that with the factory or do i have to take it out and put two aftermarket subs in
Old Nov 30, 2011 | 06:39 PM
CMOS's Avatar
CMOS
Not sure what you're asking.
My opinion is that IF you are running the SUB through an AMP, you only need ONE for that truck. Low frequency sound (bass) travels slow and hard, so in that small space one will be just fine. I suggest you replace the factory sub with a good aftermarket one.
CMOS
Jshwrdul
2004 - 2008 F150
Feb 7, 2012 06:18 PM
kaerch
2004 - 2008 F150
Dec 30, 2008 04:05 AM
jreeder41
Pennsylvania Chapter
Oct 19, 2007 02:52 PM
oubrad
2004 - 2008 F150
Nov 3, 2005 08:51 AM
fourby
Jan 20, 2000 04:06 AM
