electrical problem
Old Apr 14, 2003 | 12:42 PM
graham_patrick1's Avatar
graham_patrick1
electrical problem
My 92 f-150 runs fine for 30 minutes or so and then the voltage indicator on the dash starts to vibrate. If I shut down and try to re-start immediately, it doesn't want to ignite. After waiting it starts fine. It almost seems like it is vapor locked. The battery and alternator have both been repalced and seem to be working OK. Connections at battery are OK. Could be electrical or ignition. Help.
Old Apr 14, 2003 | 02:07 PM
Franklin2's Avatar
Franklin2
electrical problem
A truck with EFI really can't vapor lock, since the fuel pump is in the gas tank. But it could be the fuel pump is not working. Can you hear it come on if you turn the key, but not crank the motor?
Old Apr 14, 2003 | 04:09 PM
graham_patrick1
Question electrical problem
I will check this. The problem occurs about the same place each day on the way to work. I have a stretch of 10 miles or so of wide open raod. Once I get into town in the stop and go I seem to have the problems. Also I have been having problems starting in the rain and fog, but this could be a result of a loose plug wire that I found. Could be a clogged fuel filter.
Old Apr 15, 2003 | 01:15 PM
beartracks's Avatar
beartracks
electrical problem
Actually F.I. doesn't totally eliminate the possiblity of vapor lock. The voltage gauge fluctuating might indicate cavitation. I'd do the fuel filter.
Old Apr 15, 2003 | 01:32 PM
graham_patrick1
electrical problem
Changed the fuel filter. Problem is still occurring. Also I am hearing a whistling sound that I can't localize that seems to occur simultaneously with the erratic voltage. If I shut the engine down and am able to re-start, the voltage indicator acts OK.
Old Apr 20, 2003 | 02:20 AM
steve83's Avatar
steve83
electrical problem
Pull the codes and test the fuel pressure, especially at the moment you notice the fluctuation & whistle. Pull the vacuum line off the fuel pressure regulator (FPR) and see if it has gas or a crack in it.
ClintonA
Jan 31, 2017 12:36 PM
WQ59B
1947 and Older Ford Trucks
15
Mar 23, 2016 06:29 AM
reloaderbill
Nov 30, 2015 11:01 AM
Cor
Aug 11, 2004 03:51 PM
89f350
Jul 18, 2004 10:39 AM
