dual tanks problem
Old Nov 28, 2011 | 08:04 PM
cwarren90's Avatar
cwarren90
dual tanks problem
I have a 76 f150 ranger, it has dual tanks, aux and main.. i am only running the main tank because the tank selector valve has gasoline pouring out of one of the nipples? there is 3 outlets on it for hoses but only one has a hose going to it. the one on top shoots gas out when switched to the aux. tank.. please help i know a line needs to be on it but idk where it would go from there?
Old Nov 28, 2011 | 09:17 PM
supercabfreak's Avatar
supercabfreak
i have dual tanks on my truck which is also a 76 so i will asume you have the electric operated selector. on mine there are 2 hose nipples on one side and one on the oposite
suply from mani and aux go into the 2 on one side and "out" to engine is the one by itself
a picture of your situation would be helpful
Old Nov 29, 2011 | 02:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ-9189-B .. Fuel Tank Selector Valve & Solenoid Assembly / Applications: 1975/79 F100/350.
D5TZ-9A050-A .. Fuel Tank Selector Switch-also changes the dash fuel gauge from one tank to another, mounts into heater control panel / Applications: 1975/79 F100/350.
1973/74's had a manually operated selector valve on the floor, adjacent to the drivers side of the seat. The heater control mounted switch (D3TZ-9A050-A) only changes the dash fuel gauges.
Justin Braun
Apr 9, 2019 06:07 AM
jaygee15
16
Jan 26, 2019 10:31 AM
DisneysPatB
Jan 31, 2017 06:01 PM
trainguy1973
Aug 15, 2011 12:02 AM
olthunter
Sep 22, 2000 04:19 PM
