Waste Gate issue
Old Nov 28, 2011 | 01:04 PM
2000F250guy's Avatar
2000F250guy
Waste Gate issue
Ive always thought my turbo was not working properly, but now i got the right size tires on it I can really tell. So i bought a vacuum tester and put 20 (psi I think) and had no leaks. The waste gate is vacuum not pressure right? Is there any other way to test the waste gate?
Thanks in advance for the advice.
Old Nov 28, 2011 | 01:49 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Not vacuum, it works off of pressure coming from the red line off the spider.
Old Nov 28, 2011 | 01:51 PM
Shake-N-Bake's Avatar
Shake-N-Bake
It is pressure activated. Here is some more detailed info for your reading pleasure.
File Type: pdf
Old Nov 28, 2011 | 01:56 PM
2000F250guy
Thank you very much, this will help tons
Old Dec 7, 2011 | 07:08 PM
2000F250guy
ive tested the waste gate, worked fine. Tested the waste gate solenoid, changed it. still dont seem like the turbos working. A friend of mine asked if it was idleing up when cold and its not. What should i check for?
Thanks in advance.
Greywolf
General Automotive Discussion
Jun 24, 2008 05:31 PM
CrazyFazy
Bronco II
Mar 5, 2004 08:49 AM
sharpshooter
Jun 18, 2003 06:57 PM
