Vacuum Pressure
Old Jun 17, 2003 | 11:43 PM
sharpshooter's Avatar
sharpshooter
Question Vacuum Pressure
I have an 1984 302 with a 4 barrel Holley 600cfm. My vacuum pressure is registering at 20 psi.
What is the normal standard and and it is hard to achieve more vacuum pressure out of my 302?
I appreciate any information provided because I just put this 302 in my truck and I am putting the finishing touches on it and this is a question that I cannot seem to find the answer to.
Thanks.
Old Jun 18, 2003 | 08:26 AM
nickmobile67's Avatar
nickmobile67
Vacuum Pressure
If it's hanging steady at 20 inches of vacuum than that's good. It shouldn't bounce around too much. Between 18-20 is about right. Adjusting the timing can change your idle vacuum reading. Advanced timing will give a higher vacuum reading. If you hit the throttle from idle quickly and let off the vacuum should drop to around 5 and jump back up again.
Old Jun 18, 2003 | 03:38 PM
steve83's Avatar
steve83
Vacuum Pressure
Check out these diagrams.
Old Jun 18, 2003 | 06:57 PM
sharpshooter
Vacuum Pressure
Thank you so much for all your information. It was all very helpful and the diagrams are great and anyone can understand them. Thank a lot and I will take all those tips into consideration.
