Hi,
Thought maybe you guys could help. I am restoring a 58 Dodge W100 and need to find a source for the perforated cardboard (pressboard) headliner material. It is similar to the material used in my 65 F100 custom cab but the perforated holes are larger in diameter and spaced much further apart. No kits or material are available from the Dodge vendors but someone must still be making this type of material.
Would appreciate any leads. Thanks in advance for your help!
Welcome aboard Jerry; havn't seen any perforated board 9small hole) at local hardware stores; but we've use a type of panel from home depot that flex fairly well in redoing a headliner in a 62 4x4 last summer; I just can't recall the actual name of the product; The folks at lowes or homedepot should beable to direct ya to a panel that could work.
