Temp gauge not working
Old Feb 5, 2007 | 05:34 PM
B Dobz's Avatar
B Dobz
1990 f-150 302 automatic and the gauge do not move at all,The engine gives off good heat from the heater so i know the gauge shold have moved alittle,so where is the sending unit for this truck? and what else should I look at to fix this problem?Thanks for your help.
Old Feb 5, 2007 | 07:13 PM
chaseface84's Avatar
chaseface84
i believe it is right above the thremostat
Old Feb 6, 2007 | 07:47 AM
MRL123's Avatar
MRL123
Front of the lower intake manifold, drivers side, behind the distributor, in close proximity to the front fuel injector. Look for a 1 wire sending unit - the connector is a push on-pull off.
cheers!
Mike
Old Feb 6, 2007 | 05:21 PM
cpettymore7777's Avatar
cpettymore7777
you can also test the gauge by grounding the wire to it. you should see the needle move
Old Feb 14, 2007 | 09:32 PM
emiltech's Avatar
emiltech
if it does move ....replace the sensor....
