Grease Zerk on 2wd Bearing Cap
I am getting ready to put new hubs on my 2wd F-350 conversion, I was just curious if it would be worth putting grease zerks in the caps, that way whenever I grease the chassis, I can give the wheel bearings a shot or two of new grease to keep them well lubed. I know I can't put too much in cause it could blow the seal, or push the cap loose, but just a shot or two would help wouldn't it? any thoughts or comments would be appreciated.
Yes, and it works great in the little bearing packers.. But putting a zerk in the dust cap is going to cause you WAAAYYYY more trouble than pulling your hubs and doing it, plus you have a chance to inspect the bearings and races..
The grease gun can't see very well!!!
I always pack the hub with grease, and the cap, cause I figured the heat would break the grease down some, and having more grease will help disperse heat. I was thinking kinda like a bearing buddy, and the pressure of the grease being pushed in would somewhat grease the outer bearing more
I don't mean to pee on your parade, but have you ever really looked at a trailer with a bearing buddy? 9 times out of 10 the seal has been blown/pushed out and there is grease all over the inside of the tire and wheel, I don't really think this will do your brakes any good... but what do I know???
BUT, since you seem to have your mind made up, go ahead and do it, just be sure to let us know how it worked out for you....
bmwcarl
03-23-2015 10:24 PM
rustyranger390
10-10-2011 04:24 AM
Super Steve
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-14-2010 01:27 PM
PW_SD
1999 to 2016 Super Duty
10-02-2009 01:10 AM
