greasing wheel bearings
Old May 12, 2010 | 09:56 PM
Super Steve's Avatar
Super Steve
My trailer has little rubber caps on the axle stubs that say "remove to grease".
I removed them and squirted some grease into the zerks.
Am I supposed to keep squirting untill I see grease coming out of the bearings?
Old May 12, 2010 | 11:13 PM
rebocardo's Avatar
rebocardo
I have never seen that, but, I would say no, you could destroy the seals.
That being said, I usually do because I like to drive out any water if the seal is bad, wheel bearing, ball joints, etc. I usually will not do this on UJs because they are meant to be sealed tight.
Old May 13, 2010 | 06:13 AM
mistakenID's Avatar
mistakenID
Someone may have put buddy bearing caps on. There is a spring around the inside diameter
and the cap is under the spring. You put grease in until the inside cap moves out and compresses the spring. (if that is what is on your axle)
Old May 13, 2010 | 07:39 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
It sounds like you have Dexter Easy Lube axles on your trailer. You can grease the bearings by slowly putting grease into the fitting, grease will go into the rear bearing first and the old grease will be forces out of the outer bearing, when the grease coming out of the front bearing is clean all the grease has been changed out. The old grease will come out into the cap and you have to clean it out. The biggest drawback is if the seal is bad or weak it will force grease out through the seal onto the brakes if you have them.
Denny
Old May 13, 2010 | 11:37 AM
Steina's Avatar
Steina
CO River Rat
One tip - after you have nothing but clean grease coming out of the cap, use your finger to scoop out enough grease so you can see the zerk fitting. If you leave the hub completely full, your 1st trip will heat the grease enough to pop off the rubber plug and send grease flying.
Steve
Old May 13, 2010 | 09:05 PM
Billyclub's Avatar
Billyclub
I have the same lube system on my TT ( Rockwood Roo 23SS). getting ready to go next week with it and was wondering the very same thing. thanks for the info.
Old May 13, 2010 | 11:54 PM
Steina's Avatar
Steina
CO River Rat
The great thing about these E-Z Lube spindles is the ease of changing bearing grease; no disassembly required means there's no excuse not to grease 'er up at least twice a year!
Steve
Old May 14, 2010 | 08:44 AM
rvpuller's Avatar
rvpuller
One other thing I would do is jack up each wheel and check the end play in the bearings just to make sure you don't have problem ( that's what I do with our Nev-Lube bearings) and after you hook up have someone with compass hold it next to the bottom of each wheel when you apply the brakes to make sure the magnets are working.
Denny
Old May 14, 2010 | 09:20 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Denny
Hell, I never even thought about the compass...lol And I'm a Boy Scout and a Marine...lol
Old May 14, 2010 | 01:27 PM
bpounds's Avatar
bpounds
I have the Dexter EZ Lube axles too, and that is exactly what I do. Once a year. And while it is jacked up, adjust the brake shoes. I can't say I have done the compass thing, but it sounds like a good idea.
FordTruckChuck
1997 - 2003 F150
Oct 27, 2015 04:01 PM
ROADHOGE250
15
Apr 16, 2015 07:10 AM
351Cleveland C4
Aug 11, 2014 02:44 PM
LeoJr
15
Nov 30, 2013 04:30 PM
wire4money
1983 - 2012 Ranger & B-Series
May 9, 2004 05:34 PM
