Sponsored by: Real Truck
Tuner/Programmer
Old Nov 27, 2011 | 12:19 PM
GhostF250's Avatar
GhostF250
Tuner/Programmer
What Tuned/Programmer does everyone suggest for a 5.4 Triton F250 SD? My trucks lifted with big tires and want to not only get nice performance boost from it, but would also like to be able to recalibrate my speedily and shift points.
I'm looking at the SCT Tuner...
Any thoughts.....
Old Nov 27, 2011 | 12:34 PM
truckinforever's Avatar
truckinforever
SCT tuners are good. You should talk to Mike at 5 Star. He will make you some custom tunes just for your truck. Just got mine Friday for my V10 and love it. 5startuning.com or call at (843) 250-0499.
Old Nov 27, 2011 | 01:35 PM
dkf's Avatar
dkf
An SCT from 5 Star works very well and thats what myself and my dad run. That said I highly doubt you will be able to recalibrate your speedo with the tuner. On certain SD strategy codes the speedo can be changed with the SCT but you can't on the majority of them. You will want something like the Superlift TruSpeed to adjust the speedo. The tuner will help but you have to do a gear swap to steeper gears to get the most benefit.
Old Nov 27, 2011 | 01:47 PM
GhostF250's Avatar
GhostF250
I'll def be giving Mike a call.
I also plan on changing my gears. I have 6" lift with 35" Nitto Mud Graps what gear ratio you think j should run?
Old Nov 27, 2011 | 03:24 PM
dkf's Avatar
dkf
Do you do any towing?
Old Nov 27, 2011 | 03:28 PM
GhostF250's Avatar
GhostF250
Not really, when I do its my sportbike. Probably buy an enclosed later on down the road just for motorcycles though.
Old Nov 27, 2011 | 04:34 PM
truckinforever
4.30 or 4.56 should work fine.
Old Nov 27, 2011 | 05:41 PM
dkf's Avatar
dkf
I would go with 4.56 gears as 4.30s will not be steep enough. If you did a lot of heavy towing 4.88s would be better but they are overkill for what you use your truck for. The 4.56s with 35" tires will give you an effective ratio around 4.17 which will work nicely for how you use your truck.
Halfpiece
May 4, 2014 05:31 PM
acf6
Ford Truck Parts for Sale
Feb 21, 2013 01:43 AM
EODguyJake
Dec 18, 2010 07:08 AM
05rangerout07f150in
2004 - 2008 F150
Feb 19, 2010 08:47 AM
40searay
Jan 30, 2008 07:21 AM
