Sponsored by: Real Truck
coolant leak
Old Nov 26, 2011 | 06:24 PM
48prerunner's Avatar
48prerunner
coolant leak
I have a coolant leak near the passenger rear side of the engine. It's A 1999 5.4 in a f-250 I can't tell for sure if its the hard line for the heater hose or something else. On the picture i circled where i thing it may be coming from. Is it possible the intake is leaking back there. Where does the other heater hose hook up? I borrowed the pic as there is no way to see back in there with the intake on.
Old Nov 26, 2011 | 07:44 PM
leogla's Avatar
leogla
sorry to ask but, how did you know is coolant leak? did you find that last plug and gop with water?
Old Nov 26, 2011 | 07:49 PM
leogla's Avatar
leogla
by the way you got a pretty nice clean motor for a 1999
Old Nov 27, 2011 | 09:14 AM
48prerunner
I can see the coolant spray out when i start the truck. Also leaks out when i fill the tank. Just can't see if it is coming from between the intake and head of if there is a heater line that hooks up there. It does not look like its coming from the line that runs the length of the valley.
Old Nov 27, 2011 | 06:54 PM
57fomoco's Avatar
57fomoco
the other heater hose connects to a pressed in steel tube that goes into the intake manifold in the back just above where your red circle is in your picture. I've seen the tubes rot out but usually it is a heater hose. You need to use a collant presure tester and presurise the system and look for the leaks. don't forget to look at the headgaskets possibly leaking to the outside. Good luck.
steve2003
1997 - 2003 F150
Oct 15, 2018 08:08 PM
WHTTLHNTR
Nov 9, 2013 07:54 PM
redfish67
1997 - 2003 F150
May 25, 2011 10:17 PM
Joe Finn
1997 - 2003 F150
Feb 8, 2011 06:15 PM
Navdriver
13
Apr 19, 2007 02:20 PM
