Sponsored by: Auxito
Logical answer to Right side tail light problems
Old Nov 25, 2011 | 05:57 PM
murraydav's Avatar
murraydav
Just bought a 1999 f-250. Gently easing it back to normal. One niggle has popped up. Right rear tail light brake at first was intermittent along with the high mount brake lamp. Now it will not show brake. It will show running light, it will not show signal. The bulb is good. The socket is good Disconnecting at the connector near the left wheel and testing with a probe light I find blinking on only one wire. The power is not coming from the front of the truck to feed right side. The fire wire at the right rear is orange with a blue tracer. Next: Probing under the hood under the air intake I find an orange wire with a blue trace. Test light produces flash when the right signal is on. Therefore orange-blue wire is hot under the hood but not at the connector. Is there anywhere to look for a wiring diagram for the drop nosed f-150/250
Old Nov 26, 2011 | 07:05 AM
murraydav's Avatar
murraydav
Ok I think I got it nowwwww
When I signal to the right nothing happens at the rear of the truck until I move the tilt wheel up and down. Therefore the problem, I have learned through hours and hours of reading, is in the steering column Multi Function Switch. No need to pull steering wheel. Just to find the part for less than 100 bucks.
Old Nov 26, 2011 | 07:44 AM
projectSHO89's Avatar
projectSHO89
It's the column wiring harness, not the MFS, if the symptom changes with the tilt column position.
Why would anyone pull a steering wheel to investigate a turn signal problem?
TgupLou59
Apr 2, 2014 09:18 PM
Desarata
Feb 11, 2014 08:50 PM
mwood65
Oct 21, 2006 12:42 PM
redlightning93
Electrical Systems/Wiring
Sep 19, 2006 07:34 PM
Bill Led
Jul 2, 2006 01:07 PM
