Parking brake stuck......
Old Nov 24, 2011 | 03:09 PM
809taino's Avatar
809taino
Question Parking brake stuck......
My parking brake is stuck and wont release. The handle is broken so I pulled the wire with some pliers and it don't move. I did notice a Lil rust on the mechanism so i figured id spray a lil wd40 and wiggle it a bit but no luck. I'm very handy but when dealing with spring loaded hardware things can be a Lil hairy for me. I need my nubs....
Also there's a box that looks like a hard drive up under there and it's blocking access to the brake joints and hardware.
What is it and can I remove it without causing any computer issues?
The brake doesn't seem to be engaged because the truck runs smooth. Doesn't seem like it's working.
I live in the Everglades area and we ain't got no hill round here but when working up underneath the truck i feel a whole lot safer knowing she ain't moving on me..
Any Ideas?
Old Nov 24, 2011 | 05:07 PM
archtaan's Avatar
archtaan
Did you trace the cable back to the rear parking brake hat to make sure the line isnt broke, seized, etc.
Old Nov 24, 2011 | 05:13 PM
rlh68050's Avatar
rlh68050
Your worries aren't up there with the lever, they're going to be back at the splitter that goes to each rear wheel brake. Most likely you've got something stuck there. parking brakes need to be used quite often in order to not freeze up. if you haven't used it in a long time it's best not to touch it.
Old Nov 24, 2011 | 06:20 PM
809taino's Avatar
809taino
My worries are that it might be just a bit engaged and i may be overworking the engine and feeling it at the pump. It runs good but I'm wandering if it might run better.
I'm gonna trace the cables in the morning and see if they been cut or altered. My feeling is the last owner engaged it and couldn't release it and someone disengaged the cables to release the brake but the pedal stayed down.
Any Idea what the box is behind the brake?
Old Nov 24, 2011 | 06:31 PM
809taino's Avatar
809taino
I'm gonna give it another shot in the morn with better light.
Old Nov 24, 2011 | 08:40 PM
the ponz's Avatar
the ponz
The "black box" would be the Power Control Module" (PCM), which, from your photograph, is desperatly in need of a PHP or DP power chip.
The PCM can be removed by loosening the 10mm bolt which holds it to the firewall. Access to the bolt is from the engine compartment. DO NOT turn on the ignition if you are messing around with the PCM. In fact, it is best to leave the keys in your pocket or in the house until the PCM is reinstalled.
But as mentioned before, your problem is probably much closer to the rear wheels. The parking brake consists of drum brake shoes that engage on the inside hub of the rear rotors. The cable that engages them can stick anywhere along its length, but especially near the rear wheel. The brake shoes or associated cams and springs inside the hub may become sticky as well, if they are not exercised from time to time. I try to remember to set the parking brake every time I park the truck in the driveway.
If, as you say, the parking brake does not appear to be engaged with the brake pedal applied; Oh, I forgot, you said the release handle was broken, also.I would think you would want to have that working correctly. You may want to use it some day. It beats carrying around a pair of wheel chocks.
Old Nov 24, 2011 | 09:07 PM
809taino's Avatar
809taino
How desperate am I in need of that chip? And what does it do? I'm fairly new with these trucks....
Old Nov 25, 2011 | 08:20 AM
rlh68050's Avatar
rlh68050
Your not. What the poster is referring to is an aftermarket device that plugs into the PCM and alters the factory calibration to get more power.
Old Nov 25, 2011 | 09:19 AM
ExxWhy's Avatar
ExxWhy
See, just more ideas from this forum to spend money.
The handle is not too hard to change, around $40 if I recall. It was broken on mine when I got it. As others said, you'll just need to get underneath and start spraying penetrating oil in key places and work the cable until it's free.
Old Nov 25, 2011 | 09:24 AM
Sader's Avatar
Sader
Another area to check is inside the drum. That is where my problem was.
Check this thread for good pics of the inner workings.
https://www.ford-trucks.com/forums/1...-pictures.html
Old Nov 25, 2011 | 10:40 AM
the ponz's Avatar
the ponz
great write up and pics of the parking brake teardown and reassemby
Old Nov 25, 2011 | 07:09 PM
809taino's Avatar
809taino
Thanks man, amazing thread.
ajstephan
Mar 13, 2018 08:16 AM
fastredtruck76
Dec 30, 2011 12:23 AM
77f2504by4
Nov 27, 2011 01:30 PM
Ed
Aerostar
Feb 26, 2005 04:56 PM
eckart
Oct 8, 2004 02:44 PM
